Rear brake discs and pads, fitting?
Posted: Tue Mar 22, 2011 11:53 am
by seanypeeps
Hi guys done lots of searches but not really getting why I want on this. Has anyone ever done a rear disc and pad fitting guide as mine need doing and I'm not paying a garage/stealer to do it if it's pretty straight forward. I've done other cars before now but would just like a little guide if possible and is there any special tools or fitting kits needed? If you know of a link that would be great help! Cheers Sean.
Re: Rear brake discs and pads, fitting?
Posted: Tue Mar 22, 2011 12:31 pm
by Ceveman73
You need an VAG tool to wind the pistons back into the calipers I understand.
Mart.
Posted: Tue Mar 22, 2011 1:04 pm
by Rupert
Halfords do a LASER brand caliper rewind tool, that is all you need by way of specialist tools. It's quite straightforward.
Don't press the brake when the rear caliper is removed.
Posted: Wed Mar 23, 2011 7:44 pm
by mrmule
Draper do one too.
Posted: Wed Mar 23, 2011 10:22 pm
by bilko1
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Not sure if the RS6 has left and right handed pistons so you might get away with a cheap one.
Posted: Sat Mar 26, 2011 9:27 am
by micdee
I did mine about three weeks ago and yes it is very much straight forward.
But I do have a toolset like in Bilko1's link. Make sure you check your brake fluid level before you start pushing back the piston.
My fluid was filled up while the pads were half worn, so I spilled some unfortunately.
Posted: Sat Apr 09, 2011 10:44 pm
by rutland-boy
seanypeeps wrote:Hi guys done lots of searches but not really getting why I want on this. Has anyone ever done a rear disc and pad fitting guide as mine need doing and I'm not paying a garage/stealer to do it if it's pretty straight forward. I've done other cars before now but would just like a little guide if possible and is there any special tools or fitting kits needed? If you know of a link that would be great help! Cheers Sean.
http://www.yellowdogracing.com/Audibrakes.htm might be some help.......use at your own risk (!!), I havent tried it, but looks pretty straightforward as long as you have the 'special' tool, others above have said where you can get this - draper etc.
Posted: Sun Apr 10, 2011 7:11 pm
by Shoppinit
Ceveman73 wrote:You need an VAG tool to wind the pistons back into the calipers I understand.
Mart.
I bought one from halfrauds. Easiest job in the world.
