Page 1 of 2
RS6 MISFIRING ANY IDEA'S OFF CAUSE'S???????????
Posted: Fri Mar 18, 2011 8:54 pm
by RS6_2011
hey my car is misfiring like mad any idea's ive tried so many things any idea's?????????????
Re: RS6 MISFIRING ANY IDEA'S OFF CAUSE'S???????????
Posted: Fri Mar 18, 2011 9:20 pm
by scooby-tc
Vagcom is your friend
HTH
Posted: Fri Mar 18, 2011 9:24 pm
by bam_bam
Coilpacks?
Posted: Fri Mar 18, 2011 9:25 pm
by HYFR
is the RS 6 covered by the current coil pack campaign ?
Posted: Fri Mar 18, 2011 9:34 pm
by chunky79
RS6_2011 wrote:hey my car is misfiring like mad any idea's ive tried so many things any idea's?????????????
what have you tried so far?
Posted: Fri Mar 18, 2011 10:14 pm
by bam_bam
Q: what have you tried so far?
A: Putting loads of question marks in the title...
VAGCOM is your friend. Post your location and maybe someone can pop along to help.
Posted: Sat Mar 19, 2011 3:59 am
by RS6_2011
when i drive it to 2000rm the car misfire's and stutters shaking the whole car loosing power no throttle to it doesnt go over 30 to 40mph its gets really bad and engine management light flashes on and off and then stays on i did a diagnostic it showed lamber sensor and misfire cylinder detected so i changed the sensors and drove it and kept doin it again same ting misfiring and stuttering so then i tried diagnostic and it showed all the cylinders misfire detected sometimes 1/5/7 cylinder did it then 8/6/3/2 cylinder did it so i thought it would possibly be the spark plugs so i bought the NGK PFR70 plantinum the whole 8 and replaced them with the old one's deleted the code's and tryed the car again it still misfired showing no faults but on live data diagnostic showed same thing misfire cylinder detected so i thought it must be the coil pack's so i bought brand new 8 coil packs 06b 905 115 e part number and replaced them with the old one's and tried car it still misfires doin same thing showing fault code misfire cylinder detected any other idea's wat can cause this ive been told it can be a ripped pipe some where??????????????????
Posted: Sat Mar 19, 2011 7:06 am
by chunky79
F*ck me that was hard to read. Are you in the uk? If so where, cause as stated above someone might be able to scan it for you.
Could be a bad loom conection?
P.s , whats with all the question marks. ????????????????????
Just one other thing, look to the left of your ??????????????????????????? button and you will find 2 little friends ................. ,,,,,,,,,,,,,,,,,,,,
Posted: Sat Mar 19, 2011 8:55 am
by RS6Steve
I'm going loom for the fault. Get elsawin of eBay and get the wiring flow chart, pretty easy to fault find with this.
Posted: Sat Mar 19, 2011 9:21 am
by mavada
Hi Steve,
I can get you the wiring flow chart. ive got elsawin, only its in dutch...
Posted: Sat Mar 19, 2011 10:33 am
by Shoppinit
First thing to check are the little vacuum pipes. Prone to deterioration. Could be MAFs or lambda sensors. Since this is showing on the diags then it's almost certainly one of those 2. Hopefully for you it'll be the pipes or MAFs.
Don't forget to check the master cylinder vac pipe, too.
Posted: Sat Mar 19, 2011 10:58 am
by bam_bam
chunky79 wrote:F*ck me that was hard to read. Are you in the uk? If so where, cause as stated above someone might be able to scan it for you.
I know. I read that at 3am and it hurt my frontal lobe, a lot.
"Say 'ello to my liddle friends".
I'd like to start a book on vac leads, anyone?
Posted: Sat Mar 19, 2011 11:00 am
by Shoppinit
Gimme some action on MAFs.
Posted: Sat Mar 19, 2011 1:48 pm
by RS6_2011
there's nothing showing on the maf side no fault code's or any thing just cylinder misfire detected and how do i know it might be the loom?
Posted: Sat Mar 19, 2011 10:01 pm
by bilko1
RS6_2011 wrote:there's nothing showing on the maf side no fault code's or any thing just cylinder misfire detected and how do i know it might be the loom?
MAF sensors rarely show up as a fault code you need to log the data from them.
