Page 1 of 3
Inevitable
Posted: Fri Mar 11, 2011 12:35 pm
by bakustax
Have the Bilstiens ordered the DRC has had its day....latterly the whole car was bouncing at the slightest bump, similar to an old Volvo my dad had in the mid 70’s!!
I’ve read Shoppinit’s write up on the swap, looks fairly straight forward. Is there anything else apart from the Top mounts you guys would advise changing? I got a good deal, I think, from DSWagen discs all round for £1000 ,so they will be fitted at the same time...............expensive week!!
Re: Inevitable
Posted: Fri Mar 11, 2011 12:46 pm
by Shoppinit
Do the upper control arms, while you're at it. They are cheap and prone to wear. Plus any other bushes that look like they could use renewing.
It would be interesting to make a list of suspension service items with part numbers.
Re: Inevitable
Posted: Fri Mar 11, 2011 1:07 pm
by bakustax
Thanks Shoppinit............I'll get the upper arms ordered...anyone got part numbers?
Garage will asses the the bushes and replace where required
Cheers G
Re: Inevitable
Posted: Fri Mar 11, 2011 2:46 pm
by Ceveman73
bakustax wrote:Have the Bilstiens ordered the DRC has had its day....latterly the whole car was bouncing at the slightest bump, similar to an old Volvo my dad had in the mid 70’s!!
I have some nearly new Billies for sale with 2k miles on for £1000 if you wanna save £500?
Cheers,
Mart.
Re: Inevitable
Posted: Fri Mar 11, 2011 3:02 pm
by bakustax
Sorry Mart
Billies are ordered.......went for the PSS not the PSS9............£844....looked a good deal
Re: Inevitable
Posted: Sat Mar 12, 2011 10:40 am
by Shoppinit
Let us know what you think of the PSS. I've heard good things about them.
Re: Inevitable
Posted: Sat Mar 12, 2011 1:17 pm
by calummcculloch
what the difference btween ' pss and pss9'?
Re: Inevitable
Posted: Sat Mar 12, 2011 1:51 pm
by Shoppinit
The PSS aren't adjustable for damping. THey are adjustable only for height. I also believe that it is possible to set the height of the car higher than with the PSS9.
That and the price
Re: Inevitable
Posted: Sat Apr 09, 2011 12:43 pm
by bakustax
Car is booked in for the DRC/Bilstien change out and discs all round....I'm off to Baku for a couple of weeks...so all will be done for my return.Will post my impressions of the PSS set up in a couple of weeks....
Re: Inevitable
Posted: Thu Apr 28, 2011 6:01 pm
by bakustax
Bilsteins fitted and car lowered........what a difference...PSS set up is not too harsh and the car is a whole lot more planted...would recommend them as a great replacement and at £844 didn't break the bank.
One thing I have noticed is I'm getting a bit of vibration thru the brake pedal when sitting in traffic....goes if you put the car in to neutral....may have always been there and just din't notice on the DRC....anyone got any ideas?
I'm just hoping it's not as The Dead Kennedys sang in "Trust your Mechanic"......One things fixed...another falls apart!!
Re: Inevitable
Posted: Thu Apr 28, 2011 6:54 pm
by Shoppinit
I had this when I put the PSS9 on. It went away when I raised the car from face plant slammed to granddaddy standard height.
Re: Inevitable
Posted: Thu Apr 28, 2011 7:41 pm
by bakustax
She is slammed to the limit.......so yes this is probably the solution....pity....she's getting raised...but not to granddaddy standard...hopfully can find some happy medium.
On the ride I'd say it's on a par with one of my mates Z4's....certainly not crashy but when you hit a pot-hole you know all about it.
Re: Inevitable
Posted: Fri Apr 29, 2011 12:02 pm
by PHILRS6+
hi bakustax, with referance to the vibration through the pedal (accell or brake) read the linked post, i had the same.
http://forum.rs246.com/viewtopic.php?f=2&t=90576
Re: Inevitable
Posted: Fri Apr 29, 2011 1:51 pm
by bakustax
Hi Phil
I had the garage change out anything that looked worn, did the top mounts and the control arms as well.
As per previous I think I may have slammed her to far
I will try raising slightly, the PSS is height adjustable.......having said that I may just trade the slight vibration for the look
Re: Inevitable
Posted: Fri Apr 29, 2011 2:05 pm
by Shoppinit
I think you need to raise the fronts a little at least. The front looks lower than the back. This is how mine looked when it was giving me the vibrations:
