Cheap valve covers on TPM!
Posted: Sun Feb 06, 2011 8:12 pm
by Keaney
Well when it came to checking the tyre pressures on each wheel I found that some cheap valve caps had been used and have now corroded onto the valves! Even a pair of pliers doesnt seem to do the job and started to mis-shape the valve.
Now i'm torn between getting new sensors for the wheels with the valves or seeing if i can just get the valves replaced.
Any help or ideas would be greatly appreciated
RE: Cheap valve covers on TPM!
Posted: Sun Feb 06, 2011 9:10 pm
by Coxall8395
Audi do specific ones that wont fuse with metal used on the valves.
Posted: Mon Feb 07, 2011 8:53 am
by Shoppinit
Use a dremel to slice the old valve caps off. Grind a groove axially on the cap without going all the way through, then use a flat blade screwdriver to try and split the cap by inserting it in the groove and twisting. Careful not to go too deep when cutting.
Posted: Mon Feb 07, 2011 12:33 pm
by 55marcuss
The valves are £50 odd quid for four from audi
Its the alloy wheel cleaner that speeds up the corrosion, but using good quality plastic caps ( the ones with a seal inside ) is the way to go IMO
The new valves come with these..
For trouble free motoring just ditch the sensors and valves and get some bog standard rubber jokers!
Posted: Tue Feb 08, 2011 3:31 pm
by philroach
liberal use of copper grease stops the rusting , once the caps are off !
Posted: Wed Feb 09, 2011 12:41 am
by Keaney
Thanks for advice, gonna have a go at them this weekend.
Think vagcom said only one of my tpm sensors had a flat battery so tempted to leave them on for now.
Always been a fan of black plastic caps! They are less appealing to kids, functional and lightweight haha
Posted: Wed Feb 09, 2011 10:07 am
by Shoppinit
Yeah, I learned the cap lesson the hard way once. Will now never put anything on but cheapo plastic ones.
