all lights on dash for gearbox
Posted: Wed Jan 12, 2011 7:33 pm
by suly
when put in D all the dash P R N D S light up and doesnt seem to change gear its needs revving up and then bangs into gear and doesnt seem to go right seem perfect in reverse tho ??? any one expeirenced the same or have any usefull info ??
RE: all lights on dash for gearbox
Posted: Wed Jan 12, 2011 8:56 pm
by RS6Steve
Torque converter / Gearbox
Re: RE: all lights on dash for gearbox
Posted: Wed Jan 12, 2011 9:12 pm
by amanda1
RS6Steve wrote:Torque converter / Gearbox
Agreed................hope you have some sort of warrenty cover on the car
Posted: Wed Jan 12, 2011 10:10 pm
by gorwanvfr
Get a vag com on it and see what the error code is. Could be the F125 switch. Have a read of this
http://www.audipages.com/Tech_Articles/ ... place.html
Posted: Wed Jan 12, 2011 10:27 pm
by BigMo
I had the same. Found that by switching the car off an then back on seemed to cure it but the TC was shagged!
Posted: Wed Jan 12, 2011 10:58 pm
by mavada
i had the same issue, was getting worse when it was getting colder outside, replaced the f125 switch and now works great...
Not that easy to get it out, some parts has to be removed first.
The link to the audipages site is about replacing the f125 dwitch on a A8, so that is something different...
Posted: Wed Jan 12, 2011 11:31 pm
by suly
ive had it on vag and its bought out code
GEAR RATIO MONITORING INCORRECT 17114 P0730
cleared code but soon as i start it it comes back
could it be anything to do with control unit ??
Posted: Wed Jan 12, 2011 11:54 pm
by suly
thanks to all for your suggestions
Posted: Thu Jan 13, 2011 4:26 am
by S2tuner
suly wrote:ive had it on vag and its bought out code
This fault code seems to be from the engine control unit, not from the tiptronic control unit. do you have access to a VAG-Com?
Posted: Thu Jan 13, 2011 9:27 am
by Shoppinit
Could be caused by a seriously slipping brake in the box, too. Given the other symptoms (slipping and banging) I would lean towards a worn out box. But, definitely try to change the ATF first. Could be low which would give similar symptoms. Could be a sticky solenoid. Hope for best, plan for the worst.
@Mihnea, I am ready for more potatoes
Posted: Fri Jan 14, 2011 1:43 pm
by jd_hants
I had something very similar - cant remember the fault codes though - simply turned out to be low oil level in gearbox due to an oil hose coming lose and leaking. Replaced oil and has been fine (touch wood) - I was very lucky!!!
Posted: Fri Jan 14, 2011 3:25 pm
by SteveCuz
I had all the light come on 6 months after buying. I went to Audi and they changed the oil. I was convinced after reading this forum my gearbox was gone but 2 1/2 years later and everything has been sweet. Got Grizz to change the oil for a second time 12 months after the first as a precaution.
Steve
