Does the C5 have a "you've left your lights on warning&
Posted: Wed Dec 22, 2010 8:56 pm
by paddybrenn
As per title, I'm wondering whether the car has an audible noise when you leave your headlights on? I'm sure it did, but it doesn't work now if it did, so just wanted to check with others to start the investigation off.
And if it does, is there a switch or something that I've accidentally pressed to turn it back on!?
Cheers all.
RE: Does the C5 have a "you
Posted: Wed Dec 22, 2010 9:00 pm
by Fizmo100
It deffo has one - there have been a few times I'd have been screwed without it! Not sure about mute options for it though.
Posted: Wed Dec 22, 2010 9:10 pm
by amanda1
Yes mine does as well :wink:
Posted: Wed Dec 22, 2010 10:05 pm
by drybeer
Mine does, and the alarm sounds if I remove the ignition key while the lights are still on, or even if a parking light is left on.
Posted: Wed Dec 22, 2010 10:22 pm
by JCviggen
Mine doesn't eather. Wish they would just be out automatically with the key out of the ignition and the car locked, so i could leave the switch on all the time. My previous cars were all like that so now quite regularly I either have to get back into the car to turn them off, or notice that Im driving without lights in the dark.
Posted: Wed Dec 22, 2010 10:46 pm
by Coxall8395
May be the warning sound (presumably a relay on the relay panel) has died. Would have thought it would be linked to the door pin switch and if your interior lights still come on then i doubt its the pin switch
Posted: Wed Dec 22, 2010 10:56 pm
by posterboyj
they can be programmed through vagcom
