Square tires.
Posted: Tue Nov 23, 2010 9:57 am
by mavada
Is it normal when my RS6 is in my garage for a couple of days (4) without haven driven it, the car shakes like the tires are somehow having a flat surface from standing 4 days in my garage? Is this common with low profile tires?
RE: Square tires.
Posted: Tue Nov 23, 2010 9:58 am
by Daveperc
No - not normal - and I doubt it's the tyres.
Need more info, but bad handling/vibration when cold sounds like failing DRC to me
Dave
Posted: Tue Nov 23, 2010 10:03 am
by Billiemapped
Not the tyres, mine sits in the garage for days on end never had that problem.
Steve
Posted: Tue Nov 23, 2010 10:47 am
by andyt
Is it not rust on the brake discs sticking slightly?
Re: Square tires.
Posted: Tue Nov 23, 2010 11:47 am
by drybeer
mavada wrote:Is it normal when my RS6 is in my garage for a couple of days (4) without haven driven it, the car shakes like the tires are somehow having a flat surface from standing 4 days in my garage? Is this common with low profile tires?
I've certainly experienced flat spots on tyres from them standing still. This was with Dunlop Sport 9000s, and Pirelli P-Zeros, so both reasonable tyres too.
Standing for 4 days should not do it though, I would have thought a month or more?
RE: Re: Square tires.
Posted: Tue Nov 23, 2010 1:43 pm
by ChrisRS6
I agree with drybeer.
I know that I have to be careful with my old camper van when storing it over winter. You can get flat-spots on the tyres if it isn't stored properly, but only after a long time (months, not days) of it being parked in the same place, so I keep it 'parked' on Axle stands.
It isn't unusual for my other cars to be parked for longer than 4 days without moving and I've never had flat-spots on tyres.
Are the tyres particularly old or do they have some other sort of problems? Checked pressures / side-wall condition etc?
Perhaps as mentioned by others, it isn't a tyre problem at all?
Posted: Tue Nov 23, 2010 5:00 pm
by 480bhp
What dampers are you running?
Posted: Tue Nov 23, 2010 7:56 pm
by ecain63
Are your tyres quite old? If the side walls are degrading then they can develop flat spots.
Posted: Wed Nov 24, 2010 2:48 pm
by bam_bam
Do you have a heated floor in your garage?
Posted: Wed Nov 24, 2010 7:26 pm
by mavada
No ive new tyres, also no rust on the brakes. Which dampers i have? no idea, im since 2 month the new owner of the RS6. Bought it without warranty.... and yes, the F125 switch has to be replaced, at the rear of the gearbox some fluids coming out... now the bumpy ride when the engine is cold...... what happens next....never but a RS6 without warranty is dhould say by now..........
Posted: Wed Nov 24, 2010 8:16 pm
by Mikey-S
What tyres are you using?
Posted: Sat Nov 27, 2010 9:10 am
by Fingers01
Is the vibration at all speads of driving and all types or road surface.
I had vibrations at certain speeds and having read this thread thought ***K my DRC is on the blink. So jacked it up, looked for leaks,broken pipes nothing.
So process of elimination began.
Tyres - nope - new set only last month - no lumps or bumps ,side walls look good,no flat spots either
Wheel balancing - This was the problem. They had not been balanced properly, only one set of weights in the middle of the rim on each wheel and not one of them was even close.
All done no more vibrations
If not wheel balancing next step was to have tracking checked, then all the ball joints and bushes, discs but last of all on my list would have been the DRC.
But start with the cheaper to fix issues first
Yes the DRC has it's detractors and this forum is full of the negatives about the DRC system but it's not the source of all problems that occur with these cars.
