drivers door not closing
Posted: Mon Nov 15, 2010 9:52 am
by gooldie
Hope there is a simple fix to this opened up the car this morning and it has been very cold overnight ( car completely frozen) when i went to shut the driers door it wouldn't close. The latch in side the door didn't appear to be catching. is this anyone else has come across and is there a quick fix?
RE: drivers door not closing
Posted: Mon Nov 15, 2010 10:05 am
by philroach
quick fix is wait for lock to thaw out ,moisture has got into the lock and frozen , worse case scenario , it wont even open, same with windows not winding down etc
Posted: Mon Nov 15, 2010 10:06 am
by gooldie
its just unusual that it was only the drivers door! is there anything i can do to stop it happening again?
Posted: Mon Nov 15, 2010 10:15 am
by philroach
parking it in a less exposed direction might help ?
Posted: Mon Nov 15, 2010 10:22 am
by RS4XS
I too had this but with the passenger side, But it was not frozen, does it every now and again for some reason, simply doesnt catch.
Posted: Mon Nov 15, 2010 11:22 am
by andyt
My passenger door does it sometimes. It appears that the more you slam it, the less likely it is to close properly. Just pushing it gently closed works fine.
Posted: Mon Nov 15, 2010 4:27 pm
by drybeer
Lubricate the mechanism in the short run.
If eventually you're out of patience a new door latch is on the cards!.
Posted: Tue Nov 16, 2010 9:51 pm
by volkscraft
I get the same problem, Always when frosted overnight, and gently gently works but slamming/firm closing doesn't.
