Quick fuel Q
Posted: Sun Nov 07, 2010 8:04 pm
by scoobylaw
Hi
once you put 95ron fuel in the 6 then the power drops, anyone know what it drops to?
Also when you refill with 97:98;99ron does the car automatically increase it's power output or does it a resett like my old Subaru did?
Does anyone get better mpg from using higher octane fuel?
Thanks in advance
RE: Quick fuel Q
Posted: Sun Nov 07, 2010 8:10 pm
by Maximo
I run mine on Tesco 99 and get about 350 - 400 out of a tank driving to work down the M4 to London. Anything else and it drops to around the 300 mark.
RE: Quick fuel Q
Posted: Sun Nov 07, 2010 8:22 pm
by scoobylaw
Thanks mate, are you saying "anything else" as in the fuel or the route
RE: Quick fuel Q
Posted: Sun Nov 07, 2010 8:50 pm
by Shoppinit
When you put the 95 in, the engine starts to pink, so the ECU pulls the ignition timing to try and save your engine from damage. The actual effect this has on BHP is dependant on lots of other factors like the quality of your plugs, the precision of the mixture, etc. No one can say for sure.
But FWIW, when you know how the ECU struggles to protect your engine on 95 RON, it's not worth it.
Posted: Sun Nov 07, 2010 9:11 pm
by Fingers01
page 216/217 of the owners manual goes into quite bit of detail about additives and cautions about the use of low octane fuels.
100,99,98,97,95 all OK
Below 95 perhaps not
It even suggests using "genuine VW/Audi fuel additives for petrol cars"
Me I stick to TESCO's MOMENTUM @ 99 RON
Posted: Sun Nov 07, 2010 9:13 pm
by HYFR
T99 all the way
Posted: Sun Nov 07, 2010 9:35 pm
by bam_bam
Shell V-Expensive only for Darth, T-99 if I stumble upon it.
Posted: Sun Nov 07, 2010 10:37 pm
by Shoppinit
In my manual it says not to use 95 except in emergency and not to use full throttle.
Re: RE: Quick fuel Q
Posted: Mon Nov 08, 2010 9:57 pm
by Maximo
scoobylaw wrote:Thanks mate, are you saying "anything else" as in the fuel or the route
As in the fuel type used. Note to self, proof read what i type. :D
Posted: Mon Nov 08, 2010 11:55 pm
by amanda1
My fuel flap says nothing less than 95
Posted: Tue Nov 09, 2010 9:40 am
by RS6Steve
amanda1 wrote:My fuel flap says nothing less than 95
Are you sure it does not stay Super Unleaded RON 97 min.....
Posted: Tue Nov 09, 2010 10:14 am
by Shoppinit
It's a no brainer. These cars are not supposed to run on 95 octane fuel. 97 or greater. 95 in an emergency and don't use full throttle.
