Found oil
Posted: Mon Aug 09, 2010 10:01 pm
by yogi
While doing some work at the weekend I spotted nasty oily grease at the bottom side of the engine. Any clue what that is or where the oil might come from?
Posted: Tue Aug 10, 2010 12:05 am
by jamesthecat
:shock: yep same as mine by the looks of it,i have a very very small leak coming from the rocker cover,unit 20 had a look and said not worth bothering about, i noticed it about 6 moon ago and iv not noticed any drop in the oil apparently its a common prob and to sort it the engine has to be moved
Posted: Tue Aug 10, 2010 12:15 am
by jamesthecat
if your worried about that then here is another,i noticed that the rubber tubing coming off the n75s were coroded so took the air box off on Saturday and found that every bit of rubber had either cracked or fell to bits when i moved it,now that cant be good :( it was easy to replace it all as its just diesel fuel line piping took 15 mins to replace,now it runs even better than before :D and didn't even use any hammers :shock: i did get some piks but just cant get them to go on here :(
Posted: Tue Aug 10, 2010 7:47 am
by ecain63
Rocker cover? Looks to me like its coming from the oil filter housing. Where the housing meets the block (not where it meets the filter) there is bit with a couple of copper washers. They do leak from time to time and its a pretty straight forward fix, but will require a new filter housing as Audi made it a 'sealed unit' (not the cheapest fix).
Posted: Tue Aug 10, 2010 9:05 am
by Daveperc
There was a thread with pics on this a while back - try http://www.rs246.com/index.php?name=PNp ... acuum+hose
Dave
Posted: Tue Aug 10, 2010 9:17 am
by HYFR
mines going in on the wkend for leakingg rocker cover gaskets
Posted: Tue Aug 10, 2010 9:20 am
by vikingrs6
aka_dk wrote:mines going in on the wkend for leakingg rocker cover gaskets
I notice you said "gaskets" are you having both done?.. I did the passenger side a few months ago but was under the impression the drivers side has access issues and you need to drop the engine to sort - i'd be interested to know how they do it without dropping the engine if it's both sides for future reference.. ta
Posted: Tue Aug 10, 2010 10:41 am
by HYFR
its going to audi, under audi warranty, so they'll probably drop the enine an charge the warranty co eleventybillion dollarpounds
Posted: Tue Aug 10, 2010 11:25 am
by vikingrs6
aka_dk wrote:its going to audi, under audi warranty, so they'll probably drop the enine an charge the warranty co eleventybillion dollarpounds
Only eleventybillion :lol:
Posted: Fri Aug 13, 2010 4:50 pm
by jamesthecat
sorry yogi :( looks like ecain was right i thought my little oil leak was trickling onto the oil filter but now iv had a proper look it is coming from the same place as yours,but the good news is that the one from the cam cover has stopped :D
Posted: Sat Aug 14, 2010 8:20 am
by ecain63
jamesthecat wrote:sorry yogi :( looks like ecain was right i thought my little oil leak was trickling onto the oil filter but now iv had a proper look it is coming from the same place as yours,but the good news is that the one from the cam cover has stopped :D
Yay! I got something right. Hope you get it sorted mate.
