Page 1 of 2
mrc map.
Posted: Sun Jun 27, 2010 2:39 pm
by alexrs6plus
Mabye one for the mrc guys.
I allways run it on optimax.
Im going mrc to check over a map they done for me should it be checked over with optimax or normal super?
I will be going south of italy this year and getting hold of of anything but 95 ron is a pain, some places like agip do a 97 ron super and the occasional shell does 100 ron but they are quite far to go.
Does anybody know if the mrc map retards ignition to save the engine?
RE: mrc map.
Posted: Sun Jun 27, 2010 11:38 pm
by bam_bam
Get MRC to set you up with water injection, that'll have your detonation going "full <beep>"... the ONLY time you're allowed to go full <beep>.
Water/meth injection will sort your 95RON issue.
RE: mrc map.
Posted: Mon Jun 28, 2010 12:06 am
by kaisersolsay
I ran my 6 on 95 for 1000 miles in France this year with absolutely no issues. If going on long runs I sometimes use 95 here in the UK again with no issues. You do run slightly less MPG though, around -3mpg.
Posted: Mon Jun 28, 2010 1:48 am
by ElevenSec
I would have to assume that any reputable tuners map would definitely retain all safety measures. And that at the slightest hint of detonation will <beep> the ignition. And MRC is one of the best. So I would say you are safe at a lower octane rating. Just less power, that's all..
Posted: Mon Jun 28, 2010 8:36 am
by Blue_Thunder
You could always take some Octane Booster such as Millers CVL if you are that concerned, but as Vintron says, you car will perfectly safe.
Posted: Mon Jun 28, 2010 4:00 pm
by rs666
The adaptation tables will compensate if left with sensible parameters.
Posted: Mon Jun 28, 2010 6:56 pm
by alexrs6plus
Thanks guys.
Dug at mrc cleared it all up for me today.
Thanks for your posts.
Posted: Tue Jun 29, 2010 8:46 am
by philroach
what did he say was the problem ?
Posted: Tue Jun 29, 2010 9:41 am
by alexrs6plus
I had a faulty n75 valve so was running about 0.5-0.6 bar.
Car would sound fast but wasnt going as fast as i remember.
All sorted now.
looking at a full milltek now.
Posted: Thu Jul 01, 2010 3:50 pm
by el_ringo
How much is water/meth injection?
Re: RE: mrc map.
Posted: Fri Jul 02, 2010 12:15 pm
by tartan_rob
bam_bam wrote:Get MRC to set you up with water injection, that'll have your detonation going "full <beep>"... the ONLY time you're allowed to go full <beep>.
bam bam - any idea what WI gives you performance wise? I know about reduced burn temps and better timing etc but in reality what does it bring to the party? I am about to install it and am curious.
RE: Re: RE: mrc map.
Posted: Fri Jul 02, 2010 12:16 pm
by tartan_rob
<beep> - wrong forum.
Posted: Fri Jul 02, 2010 12:28 pm
by SteveCuz
Move on and come back when u buy another 6!!
LOL
Steve
Posted: Fri Jul 02, 2010 3:21 pm
by bam_bam
I'm not sure about how HP useful it'll be on a NA car other than levelling a RON deficit and of course cooling and air density. There's a theory that it will keep intakes clean on direct injection engines, might be great news for you B7 boys! I've got a couple of mates that run water/meth (mostly meth) on their scoobys in Australia. Without their meths it's about a 10-20% drop in power. But some of them are running 20 to 25 psi boost
I'd also read somewhere that some yank 335i drivers were getting great results, again, forced induction. Americans love it because their fuel is so sh1te.
I'm not sure of your reasons but I assume you've spoken to MRC? Surely they could tell you a lot more, if so, I'd like to know more too. Feed the backs.
BTW Rob, how much (all in) was your kit?
Posted: Fri Jul 02, 2010 4:53 pm
by bam_bam
http://www.aquamist.co.uk/sl/plist/frm-4.html oooo, just found this, only thing missing is the tank.
