Page 1 of 5
Brake Discs
Posted: Tue Jun 15, 2010 6:28 pm
by Wint11
Is it true that you can only get standard discs for the RS6? Spoke to someone at Venom Motorsports today and they claimed no one manufactures discs other than Audi.....
RE: Brake Discs
Posted: Tue Jun 15, 2010 7:53 pm
by ecain63
True it is! Although if you wanna go bigger then there are a couple of kits out there.
RE: Brake Discs
Posted: Tue Jun 15, 2010 8:15 pm
by Shoppinit
YOu can put Phaeton disks on the rear with some slight mods. DK did it.
RE: Brake Discs
Posted: Tue Jun 15, 2010 9:31 pm
by Cornishmoocher
Actually Eddie ( and we don't disagree on much if anything) Movit do a brake kit for the RS6, but they are eleventy billion quid.
RE: Brake Discs
Posted: Tue Jun 15, 2010 9:46 pm
by bam_bam
Mov'it do big brake kits both front and rear. Stoptec callipers will fit on the rear (sans hand brake function). According to Grizz, the C6 rear disc can be fettled to fit on the C5 rear. I think Sportec do C5 RS brakes too but they're 380mm and probably 8 pots, no doubt cost the earth.
I've got C6 RS 390 front discs and 6 pot callipers fitted to the front of my C5 RS. Now they're broken-in they are truly bonkers, they'll break your neck and slam your head in your lap.
RE: Brake Discs
Posted: Tue Jun 15, 2010 9:51 pm
by Cornishmoocher
They are quite good aint they?
RE: Brake Discs
Posted: Tue Jun 15, 2010 9:56 pm
by bam_bam
I was stomping on them relentlessly and I'd hazard a guess my frail and meek DRC couldn't handle the punishment those huge brakes were dishing out.
Re: RE: Brake Discs
Posted: Tue Jun 15, 2010 9:58 pm
by ecain63
Cornishmoocher wrote:Actually Eddie ( and we don't disagree on much if anything) Movit do a brake kit for the RS6, but they are eleventy billion quid.
I did say there were kits out there. .............
'True it is! Although if you wanna go bigger then there are a couple of kits out there.'
So we definately dont disagree on anything then.
RE: Re: RE: Brake Discs
Posted: Tue Jun 15, 2010 10:03 pm
by Cornishmoocher
I really should learn to read......... That went in one eye and out the other!
Posted: Tue Jun 15, 2010 10:04 pm
by bam_bam
IIRC - I think he meant Mov'it do an OEM spec fit. Meaning Audi aren't the only ones to make discs for the C5 RS. Although, I could be wrong.... Yup, I was. I'll get me coat.
Posted: Tue Jun 15, 2010 10:12 pm
by bam_bam
Mov'it do a 370x35 disc for the C5 RS, not sure if that's a straight fit though. The OEM is 365x33.
Posted: Wed Jun 16, 2010 5:30 pm
by Wint11
Got standard discs on the way. Cheers chaps.
Re: Brake Discs
Posted: Sat May 07, 2011 6:22 pm
by mrmule
Sorry to resurrect this thread but couldnt justify starting another.
Whats the height of the front C5 disc?
Re: RE: Re: RE: Brake Discs
Posted: Sat May 07, 2011 6:46 pm
by bam_bam
This.
bam_bam wrote:Mov'it do a 370x35 disc for the C5 RS, not sure if that's a straight fit though. The OEM is 365x33.
Re: Brake Discs
Posted: Sat May 07, 2011 8:18 pm
by mrmule
Yep that's interesting too.
Back to the other thing, if the disc is lying flat on the ground, what is it's height, as opposed to diameter and thickness?
