Page 1 of 2
580PS RS6
Posted: Sat May 08, 2010 5:37 pm
by Doug_S2
Bolt on Hybrids, Manifolds, full exhaust and Wagner ICs.
More can be had if intake temps were lower on the dyno - better ICs or water injection.
Don't expect more torque than a tuned rs6 as it is held back a lot. It pulls hard to high revs. It will pull to 7k - just got the gearbox chip to tweak to do that.
RE: 580PS RS6
Posted: Sat May 08, 2010 5:39 pm
by grizz
well done mate. Is that your's ..
RE: 580PS RS6
Posted: Sat May 08, 2010 5:47 pm
by Doug_S2
It is hers.
RE: 580PS RS6
Posted: Sat May 08, 2010 5:51 pm
by grizz
haha , you know what i meant .. Would it make more with stage 2 hybrids ..?
RE: 580PS RS6
Posted: Sat May 08, 2010 6:02 pm
by Doug_S2
These are the k06 wheel hybrids with hotside mods so I doubt there is more to be had out of these flow wise. Just a manual box will make it feel better!
Re: RE: 580PS RS6
Posted: Sat May 08, 2010 6:06 pm
by chunky79
Doug_S2 wrote:These are the k06 wheel hybrids with hotside mods so I doubt there is more to be had out of these flow wise. Just a manual box will make it feel better!
so when you changing the box then
RE: 580PS RS6
Posted: Sat May 08, 2010 6:11 pm
by Doug_S2
The manual car on wastegate boost feels a LOT faster
Re: RE: 580PS RS6
Posted: Sat May 08, 2010 6:12 pm
by Doug_S2
chunky79 wrote:Doug_S2 wrote:These are the k06 wheel hybrids with hotside mods so I doubt there is more to be had out of these flow wise. Just a manual box will make it feel better!
She likes the auto.
RE: Re: RE: 580PS RS6
by ecain63
Good show doug. Always pushing the boandaries.
Posted: Sat May 08, 2010 7:37 pm
by Golffather
Fantastic, pushing the boundaries as always
Well done!
Posted: Fri May 14, 2010 9:56 pm
by spurtle
What's wastegate boost?
Re: RE: Re: RE: 580PS RS6
Posted: Fri May 14, 2010 10:04 pm
by S2tuner
spurtle wrote:What's wastegate boost?
Mechanical boost as provided by the wastegate springs only, i.e. ECU boost control circuitry "disconnected".
RE: Re: RE: Re: RE: 580PS RS6
Posted: Mon May 17, 2010 10:50 am
by paul_23
So what is the boost measured then? I reckon it would need to be 1.2-1.3 bar at peak to get these figures (?) but can these hybrids hold that boost for the full rev range as I notice the torque curve drops off after 4700?? Have you changed the head gaskets as I think the MTM stage 4 580hp conversion changes these.
Posted: Fri May 21, 2010 8:08 am
by 650RS
I would also like to know the boost pressure across the rev range. I am fairly confident if the OEM actuators are retained and unmodified the boost will be at most 0.9bar at redline.
Turbo dyanamics in the UK is who will be performing the upgrade on my turbos with the addition of custom made actuators with a base pressure of 0.8-1.0bar compared to the 0.4bar the OEM units.
Posted: Sat May 22, 2010 8:18 am
by Doug_S2
the torque drop off is not as severe as the graphs shows - the lower scale of torque on the right side does not start at 0.
boost isn't everything and we try to make the engine as efficient as we can instead of forcing it. We use tubular manifold, good exhaust, thick headgaskets, better ICs and the next stage is a better intake system to test to get it higher.
