Page 1 of 2
Secondary air pumps
Posted: Tue Mar 16, 2010 10:08 am
by marmite
My secondary air pump has gone very noisey again
this is the third one on the car now
Anyone else had to replace theres
First one was replaced as it was making a thumping noise which got fairly loud
Bought brand new one from ebay(audi surplus stock) but that went noisey after a couple of months
Got another..yes Ebay but used OK but now just started to get noisey then this morning sounds more like a Dyson then a RS :oops:
I can also hear a thumping noise aswell...very strange all was ok for 60k then in the last 6 had 2 secondary air pumps replaced
RE: Secondary air pumps
Posted: Tue Mar 16, 2010 10:13 am
by Daveperc
Mine went noisy recently. Took it to MRC who simply wired it out of the system and reset the ECU so it doesn't object - very seeemple as that Meercat says!
The system is only there to meet some compliance regs in Europe and is not needed for running in UK
Dave
Posted: Tue Mar 16, 2010 10:55 am
by 650RS
I have removed the entire system from my car and had my tuner "kill" the codes so it doesnt throw a DTC
Posted: Tue Mar 16, 2010 11:44 am
by TIMSRS
Mine got full of water and sounded like a kettle boiling, MRC took it out and cleared all codes.
They are only used when first started when engine is cold.
Posted: Tue Mar 16, 2010 1:18 pm
by slimmyreed
yep, had mine removed aswell.
Posted: Tue Mar 16, 2010 3:00 pm
by marmite
might give MRC a call
Posted: Tue Mar 16, 2010 4:35 pm
by marmite
my car is standard so need to spend £550 on a MAP before he can do that.
really want to find out what keeps making them fail, 3 in 6000 miles
Posted: Tue Mar 16, 2010 7:52 pm
by drybeer
Mine have become noisy when the car is started in very low temeratures, and no noise at all in normal temps.
The sound is like a turbine whine - the Dyson analogy above is close!
At the same time the usual cold start habit of the car being very lumpy and a real "Bubba Bubba Bubba Bubba" exhaust sound accompanied with the OTT torque in parking maneuvers has gone...
I understand they are there to ensure the cats warm up more quickly.
Is there not a reason for this part being on the car?
I'm getting a service in the next couple of weeks so will get them checked...
Posted: Tue Mar 16, 2010 7:56 pm
by Shoppinit
The secondary air system is designed to enable the catalytic converter to heat up and reach its operating temperature more quickly after a cold start.
Because of the over-enrichment of the mixture in the cold start phase, the proportion of unburned hydrocarbons in the exhaust gas is higher. The secondary air system improves the afterburning (oxidation) process in the catalytic converter, and thus reduces toxic emissions. The heat generated by oxidisation accelerates the light off of the catalytic converter and significantly improves exhaust gas quality during warm-up.
So it's just to satisfy the greenies.
Posted: Tue Mar 16, 2010 7:57 pm
by RS6Steve
Mine sounds like a hoover, always has done. Thought it was normal? then after a couple of mine it goes off
Posted: Tue Mar 16, 2010 8:01 pm
by Shoppinit
Do you mean the sound like a Jet engine spooling up? I love that sound!
Re: RE: Secondary air pumps
Posted: Tue Mar 16, 2010 8:23 pm
by el_ringo
Shoppinit wrote:Do you mean the sound like a Jet engine spooling up? I love that sound!
Isn't that A/C pump?
RE: Re: RE: Secondary air pumps
Posted: Tue Mar 16, 2010 8:38 pm
by RS6Steve
Jet engine, yeah..... I love the wind down noise. When it's running the car sound much more powerfull....
Sorry a little off topic
Posted: Sun May 09, 2010 8:57 pm
by drybeer
Just bringing this subject back to the fore - I'm going to replace mine.
It's so damn noisy.
Does anyone on here have a brand new one they want to sell?
It's just incase I can get one that way instead of buying new.
Re: RE: Re: RE: Secondary air pumps
Posted: Sun May 09, 2010 10:59 pm
by marmite
drybeer wrote:Just bringing this subject back to the fore - I'm going to replace mine.
It's so damn noisy.
I got the last one off ebay same as An A8 one
Audi looked into the fault and found secondary air flow incorrect on one Bank,. the valve on the back on the head sticking, this is what is causing the Air pump to fail
So it might be worth having that looked at first mine did 60K no probs, but now had 3 fail.
she is going to Audi tuesday to have loads done so I will let you know if the thumping noise has gone
