Page 1 of 2
Double Din Stereo Fitting Kits
Posted: Fri Mar 12, 2010 9:16 pm
by lindowkid
Has anyone used/can recommend any after market double din kits. I have been told that my Kenwood double din (DNX-7200) won't fit in the cage ? Wondered if anyone else has fitted a Kenwood into one ?
http://shop.audioimages.co.uk/connects- ... -2783.html
RE: Double Din Stereo Fitting Kits
Posted: Fri Mar 12, 2010 11:55 pm
by Shoppinit
Posted: Sat Mar 13, 2010 7:39 pm
by GarethRS
Hi,
I fitted my Kenwood DNX-5240bt last week . The kit you refer to wont fit, you dont need the cage. I actually used my dual single din rubber face plate I brought a while back and just cut out the center bit, it's actually the same as the double one. It's a very tight fit and i havent even yet push in any of the securing tabs.
Really impresssed with the Kenwood and i'm using the roof Shark fin antenna for the GPS.
Posted: Sun Mar 14, 2010 10:04 am
by lindowkid
Gareth which facia do you recommend then? And which sharkfin did you buy?
Posted: Sun Mar 14, 2010 12:04 pm
by lindowkid
I could just do with someone sending me the links for the facia and lead adapters and any fitting accessories I need. Anyone help ?
Posted: Sun Mar 14, 2010 7:59 pm
by Shoppinit
Posted: Sun Mar 14, 2010 8:51 pm
by GarethRS
I didn't need the one with the cage for my kenwood.
This site has most of the bits you need;
http://www.dynamicsounds.co.uk/double-f ... 1_747.html
You will need a double din face plate, the one without the cage at the bottom of the page at £10 won't break the bank if it's wrong.
I'm using the existing sharkfin antenna on my roof, still testing it as I only fitted the adapter on Friday and haven't used the car all weekend. First impressions not as good as the supplied gps antenna, but need to check this week.
Re: RE: Double Din Stereo Fitting Kits
Posted: Mon Mar 15, 2010 9:18 am
by lindowkid
Shoppinit wrote:What"'s wrong with this:
http://www.caraudiodirect.co.uk/audi-a6 ... e=googleps
Thats what I thought but apparently a kenwood double din isn't Iso so this surround and cage won't fit ? can't get anyone to verify this though. Also the unit I have (dnx720) has a tilting screen so needs different surround. The posts here also seem to think I don't need a cage. So the only thing in the kit that I need is the facia. May aswell buy the separate one.
Also not sure if I have BOSE front and back or just back as this seems to be important for the terminal connectors/adapters.
RE: Re: RE: Double Din Stereo Fitting Kits
Posted: Mon Mar 15, 2010 10:58 pm
by GarethRS
If you have an RS6, which I assume you do, it will be a full Bose, front and back amp'd plus sub in the boot.
You will also need an fm radio adapter, about £7.
Posted: Mon Mar 15, 2010 11:03 pm
by woodlum
Where in the boot in an avant is the amp and sub located?
Posted: Mon Mar 15, 2010 11:04 pm
by Shoppinit
On the right behind the trim door.
Posted: Mon Mar 15, 2010 11:05 pm
by GarethRS
Oh, yes, update.
I have now fitted the kenwood supplied gps antenna. The roof one on my rs was pants. Not sure if it was duff or just rubbish, but I was only getting about 3 satelites and that was after driving 15 miles on an open motorway.
I installed the kenwood gps antenna today along with the microphone for the Bluetooth phone and on the way home today I could see over 10 satelites and that was as soon as I left.
FYI, I installed it in the roof, above the front interior light cluster. The gps antenna had a magnet and it's "stuck" to my roof, on the inside of course! Also mounted my microphone between the two lights.
Took me about 30-40 mins to remove the a pilar trim and chase the wires though.
Posted: Mon Mar 15, 2010 11:14 pm
by lindowkid
This is so frustrating... I have removed the RNS-D and an old Nokia craddle that was in the car. Tried the DNX-720 I really think it needs a craddle as its kind of flopping about loose, Gareth did you fit a craddle and what fixings did you use ? Where did you fit the Bluetooth unit ? damn it need some light/time...
Posted: Mon Mar 15, 2010 11:51 pm
by GarethRS
The only cradle I fitted was the one that came with the kenwood.
I can take some pictures tomorrow if you like.
My kenwood "5240bt" comes with Bluetooth built in. I also ran the iPod/iPhone lead to my armrest and like you, removed the old nokia phone and cradle.
I also ran a video out to the arm rest for if I ever plan to use rear screens for the kids.
Posted: Mon Mar 15, 2010 11:53 pm
by GarethRS
Where are you in the uk not in Kent are you?
