Which oil for the 6? 30, 40 or 60?
Posted: Fri Feb 19, 2010 11:14 pm
by Shoppinit
I'm trying to get my head around the different oil grades. Not interested in brands.
Manual says 5w40 VW505.01
Audi put in 5w30 VW507.00 last time I had an oil change
Some people swear by 10w60
60 sounds awfully thick to me. I used to put 50 in my mk3 escort to stop it smoking
Am I OK on 5w30?
RE: Which oil for the 6? 30, 40 or 60?
Posted: Sat Feb 20, 2010 12:19 am
by GarethRS
I do my own oil changes and researched this a while back.
I chose Mobile Edge 5w/30. Two reasons;
It was recomended on here and it is available over the shelf from Halfords.
Hope this helps
Re: Which oil for the 6? 30, 40 or 60?
Posted: Sat Feb 20, 2010 1:41 am
by skyegtb
I also do my own oil changes and use 5w40 VW505.01 simply because this is the manufacturers recommended oil for the car.
Posted: Sat Feb 20, 2010 9:17 am
by Shoppinit
skyegtb wrote:I also do my own oil changes and use 5w40 VW505.01 simply because this is the manufacturers recommended oil for the car.
This logic appeals to me, but I believe that the 505.01 (some of which is 5w30, but most is 5w40) has been superceded by the 507.00 which is all 5w30. This didn't exist when the original recommendation was made.
Posted: Sat Feb 20, 2010 9:21 am
by skyegtb
Shoppinit wrote:skyegtb wrote:I also do my own oil changes and use 5w40 VW505.01 simply because this is the manufacturers recommended oil for the car.
In that case it must be safe to assume that the new 507.00 must be compatible, if not better than the older 505.01 spec oil? Personally I will be sticking to the 505.01 for at least the next 3 oil changes as I recently bought a 25 litre drum of the stuff!
RE: Re: Which oil for the 6? 30, 40 or 60?
Posted: Sat Feb 20, 2010 9:23 am
by RS6Steve
Got my oil from Audi as per the manual £25.
Posted: Sat Feb 20, 2010 5:50 pm
by tartan_rob
I use race oil. Motul 0w20 300v high rev.
Posted: Sat Feb 20, 2010 5:55 pm
by Shoppinit
Yes, but you are insaaaaane
Why 20? What's the idea behind it? Not being critical, just interested to know.
Posted: Sun Mar 07, 2010 10:55 pm
by mtech114
If you want your engine to last platinum 5w40 fully synthetic can not be beaten!! The 40 indicates the thicker viscosity at opperating temperature! The specially formulated 1.9 tdi pump Duse oil was originally recommend, from day 1! Pd cam lobes were subject to higher opperating loads/increased friction! So it was advised for use in the rs6 engine to ruduce cam lobe wear!!! Platinum 5w40 is a pd oil! 0w30 is like tap water! Ok to use but I'd pass!
Posted: Sun Mar 07, 2010 10:56 pm
by mtech114
If you want your engine to last platinum 5w40 fully synthetic can not be beaten!! The 40 indicates the thicker viscosity at opperating temperature! The specially formulated 1.9 tdi pump Duse oil was originally recommend, from day 1! Pd cam lobes were subject to higher opperating loads/increased friction! So it was advised for use in the rs6 engine to reduce cam lobe wear!!! Platinum 5w40 is a pd oil! 0w30 is like tap water! Ok to use but I'd pass!
