Brake Fade.
Posted: Fri Feb 19, 2010 1:27 pm
by Knutts
Had some major issues with overheating brakes and brake fade at a driving expeirence yesterday. See previous post.
The OEM brakes were not up to the job. What upgrades do people recommend? Will drilled discs help or do I need something more?
RE: Brake Fade.
Posted: Fri Feb 19, 2010 1:52 pm
by Rupert
Do you have the phaeton cooling ducts upgrade?
Grizz offers an upgrade for the discs to C6 size, which uses a bracket to move the existing caliper out and therefore use the original pads. Probably the cheapest option.
Have you changed your fluid recently? It should be changed every 2 years, I had much improved pedal feel after mine was done.
Posted: Fri Feb 19, 2010 1:59 pm
by Knutts
Everything is standard and the brake fluid was changed within the last year.
Posted: Fri Feb 19, 2010 4:19 pm
by grizz
Pheaton duct kit , Drilled discs or the 390mm disc kit will the the dogs.... grizz
Posted: Fri Feb 19, 2010 4:53 pm
by GardinerG
As I said on your other post Knutts, I use ATE super blue fluid as it's much better than stock and as Grizz says fit the Phaeton cooling ducts. :thumbs:
HTH
Grant
Posted: Fri Feb 19, 2010 7:18 pm
by ecain63
grizz wrote:Pheaton duct kit , 390mm disc kit will be the dogs.... grizz
Thats gonna be next on my shopping list, once the Miltek is on and the map changed. See you in the summer Grizz me thinks.
