Page 1 of 2
rear brake discs
Posted: Wed Jan 13, 2010 8:37 pm
by rol
Why are te rear discs more expensive?
R.
RE: rear brake discs
Posted: Thu Jan 14, 2010 8:20 am
by ecain63
Because its Audi, most likely. Nothing should be assumed when pricing audi spares.
Phone Grizz at Unit 20. He'll sort you out.
Posted: Thu Jan 14, 2010 8:28 am
by CliveH
Surely not??! They're smaller to start with
But are there any alternatives?
Posted: Thu Jan 14, 2010 8:33 am
by ecain63
No alternatives to OEM ones.
Posted: Thu Jan 14, 2010 8:43 am
by CliveH
Nothing from the Phaeton range?
Re: rear brake discs
Posted: Thu Jan 14, 2010 10:10 am
by Golffather
rol wrote:Why are te rear discs more expensive?
R.
I assume you're comparing with prices for the fronts, in which case you're mistaken, the rears are cheaper. However, non-drilled are considerably cheaper than drilled for fronts and rears.
Re: RE: rear brake discs
Posted: Thu Jan 14, 2010 10:38 am
by HYFR
CliveH wrote:Nothing from the Phaeton range?
yes Phaeton rears work, had them on my old RS 6. £75 a disc direct from VW
RE: Re: rear brake discs
Posted: Thu Jan 14, 2010 10:39 am
by Daveperc
The Phaeton rears (undrilled) are cheaper (why???) and fit straight in I believe. Check with Grizz or MRC
Dave
Posted: Thu Jan 14, 2010 11:01 am
by HYFR
not a straight fit, needs a small spacer on the bolts I believe
Grizz fit mine
Posted: Thu Jan 14, 2010 11:03 am
by rol
I have just bought non drilled front discs 315 pounds for the pair delivered but got quoted 500pounds for the rear pair of the same company.
R.
Posted: Thu Jan 14, 2010 11:11 am
by Daveperc
Front price sounds about right, but I suspect that dealer has quoted for two pairs on rear.
Try DSGWagen in Doncaster - they are usually pretty low cost, or of course give Grizz or MRC a call.
I have a feeling the Phaeton ones were really cheap (?£68/disk?) so even with the extra cost of a spacer or two, may be the way to go. DK - how much was the whole set up??
Dave
Posted: Thu Jan 14, 2010 11:56 am
by HYFR
it didnt cost any more for a spacer, im not talking about a spacer you'd put on a wheel, i think it was a spacer for the bolt...
they cost me £75 inc vat each from VW grizz just charged labour to fit
Posted: Thu Jan 14, 2010 11:59 am
by Golffather
The RS6 non-drilled discs aren't that much more than the Phaeton rears IIRC
Posted: Thu Jan 14, 2010 12:00 pm
by Daveperc
Spacer as in washer (to make bolt shorter) or sleeve (to make bolt bigger)??
Certainly sounds like the way to go - though they aren't drilled of course
Dave
Re: RE: Re: rear brake discs
Posted: Thu Jan 14, 2010 12:14 pm
by HYFR
Daveperc wrote:Spacer as in washer (to make bolt shorter) or sleeve (to make bolt bigger)??
Dave
yes thats the one, though not sure which (prob washer)
they can prob be had cheaper from non VW dealer, I tried GSF at the time but they were useless
