Page 1 of 2
Sat nav in DIS
Posted: Thu Jan 07, 2010 11:23 am
by JonW
Can anyone suggest why the sat nav info will not display in the DIS on my Plus?
Thanks,
Jon
RE: Sat nav in DIS
Posted: Thu Jan 07, 2010 11:42 am
by Shoppinit
Your TCM/Canbus module may be dead. Do your steering wheel buttons work? What about the menu button by the handbrake?
RE: Sat nav in DIS
Posted: Thu Jan 07, 2010 12:53 pm
by HYFR
do the sat nav buttons on the unit light up when you switch your lights on
RE: Sat nav in DIS
Posted: Thu Jan 07, 2010 1:33 pm
by Shoppinit
Can you rub your tummy and pat your head at the same time?
RE: Sat nav in DIS
Posted: Thu Jan 07, 2010 1:49 pm
by batty
have you tried toggling the display. the button at the base of the RH stalk toggles between computer, nav and no-display.
from memory, the default from startup is to display the nav info...
Re: RE: Sat nav in DIS
Posted: Thu Jan 07, 2010 3:35 pm
by JonW
Thanks for the replies.
No buttons on wheel. Menu button works fine.
Yes; will that help?
Not sure which lights you mean?
Yes, just toggles between comp and no-display.
RE: Re: RE: Sat nav in DIS
Posted: Thu Jan 07, 2010 3:41 pm
by Shoppinit
I presume you've actually programmed a destination in?
Posted: Thu Jan 07, 2010 3:44 pm
by Shoppinit
Is it RNS-D or E?
Posted: Thu Jan 07, 2010 3:49 pm
by JonW
RNS-E and, yes, with destination set!
Posted: Thu Jan 07, 2010 4:00 pm
by Shoppinit
Is it a retrofit? Can't remember if all plusses had E. Have you got a vagcom?
Have you got the security code for the radio? You could try a reset. You could disconnect the battery for a few minutes and reconnect it. This is recommended for suspected trouble with the TMC/Canbus module.
Posted: Thu Jan 07, 2010 4:10 pm
by JonW
Standard on plus.
No vagcom.
Will have code somewhere so I will have to root it out and try the reset.
Posted: Thu Jan 07, 2010 8:20 pm
by JonW
Reset hasn't helped. Any other thoughts or will I have to resort to £s at the stealers?
Posted: Thu Jan 07, 2010 8:39 pm
by batty
mine is a plus, and yes RNS-E is std on plus's. mine shows nav on the DIS, even if there is no destination set.
In fact it's a bit of a pain, as have to toggle twice to get fuel data every time from startup....
but sorry - don't know what your fault could be.
Posted: Thu Jan 07, 2010 9:59 pm
by andyt
JonW wrote: do the sat nav buttons on the unit light up when you switch your lights on
What he means is that when you put your lights on, all the buttons on the dash light up red. This should include all the buttons on the RNS-E too, which it does by responding to a message on the canbus. If the canbus is faulty to/from the RNS-E (so that messages don't get to the DIS), then the message to turn the lights on may well not get through too. I guess that's what he's thinking.
Posted: Fri Jan 08, 2010 9:45 am
by JonW
andyt wrote:JonW wrote: do the sat nav buttons on the unit light up when you switch your lights on
I see; yes, all the buttons on the unit and dash come on.
