TPMS Codes - Flat Batteries?
Posted: Fri Nov 27, 2009 10:32 am
by RS6Steve
I believe these are tied to flat batteries in the TPMS sensors?
Got no response from the VAGCOM forum....
I don't want to spend a fortune on them if it could be something else.
01467 - Front Left Tire Pressure Sensor (G222)
53-10 - Supply Voltage Too Low - Intermittent
01468 - Front Right Tire Pressure Sensor (G223)
53-00 - Supply Voltage Too Low
01469 - Rear Left Tire Pressure Sensor (G224)
01521 - Sensor for Tire Pressure
All help appreciated
RE: TPMS Codes - Flat Batteries?
Posted: Sun Nov 29, 2009 9:13 pm
by Shoppinit
That's it I'm afraid. The batteries are dead or dying. You'll need to replace all 4 or turn the system off. jd_hands bought some aftermarket ones.
http://www.rs246.com/index.php?name=PNp ... light=tpms
Posted: Mon Nov 30, 2009 9:22 am
by RS6Steve
I'll probably get some new ones!
Thanks will take a look
Posted: Mon Nov 30, 2009 10:06 am
by philroach
i got a new set from alloywheelsdirect , not cheap , but its nice to have the OK symbol up on the display , rather than beeps , and being told you have turned your tpms off !!
Posted: Mon Nov 30, 2009 11:11 am
by RS6Steve
That was my thought Phil, not seen the OK before. When I got the beast it was switched off! Still got the price down because of it
Posted: Mon Nov 30, 2009 11:53 am
by Shoppinit
I do like having everything working properly. It would distress me if the TPMS on mine failed. Also, I think that it's good to know when your tyre is loosing air pressure when you're doing 120mph
Posted: Mon Nov 30, 2009 12:43 pm
by RS6Steve
They are expensive for what they are.....
The pleasure of owning a 6!
Posted: Mon Nov 30, 2009 2:21 pm
by jd_hants
Mine weren't dead - they just didn't exist!!!! Previous owner / tyre depot had just removed them!!!! Yes the ones from alloywheelsdirect are still working well
Posted: Sun Dec 06, 2009 3:41 pm
by RS6Steve
Anyone know the Audi part number for them?
Posted: Wed Dec 09, 2009 10:59 pm
by simon37
I was quoted about £150 per tyre to replace parts. seems a lot. Is that right?
Posted: Wed Dec 09, 2009 11:09 pm
by el_ringo
Sensors are around 75 and the valve 12. Most places will fit those at no extra cost with new tyres.
Posted: Thu Dec 10, 2009 8:18 am
by RS6Steve
Just got mine delivered £75 each and having them fitted today with my new tyres for £0.
Posted: Thu Dec 10, 2009 2:45 pm
by jd_hants
yes mine fitted at no cost. only takes a minute for each wheel!
Posted: Thu Dec 10, 2009 2:48 pm
by jd_hants
....there doesnt seem to be any specific learning procedure either. all i did was switch the system off in the menu and then on again and then store pressures. all seems to work without any problem.
Posted: Thu Dec 10, 2009 3:24 pm
by RS6Steve
Agree, checked the manual and the instructions with the sensors. Just turn it on and store the pressures....
