Engine light. Secondary airbanks
MountainMutant
Roughly once a year my engine light has come on with the error Secondary airbank left and right intermittent. (not got actual error code at the mo)
It is now coming on every month so something needs looking at as I can also feel she is not as quick as she should be.
Anyone had this? It's basically got too much air in the system for a split second which sets the light off. Last time garage thought it could be a Lamba sensor problem and to get saving!!
MM
MM
RS6-4dr911
- 1st Gear
MountainMutant
If it's just the vacuum hoses then the answer is £11.68 - see http://www.rs246.com/index.php?name=PNp ... acuum+hose
MountainMutant
Rottweiler1975
Fault Codes: 17819 P1411 002 - Bank 2, secondary air system throughput too low. Also; 17831 P1423 002 - Bank 1, Secondary Air system throughput too low
I have recently had the same problem, took it to Fife Seat who are supposed to be an authorised Audi service centre and they replaced a split hose free of charge.
One month later same problem, as I was on holiday took it to Highland Audi who checked system for leaks and valve function with no faults, they did tell me however that Fife Seat had used tye wraps which are not strong enough to hold the pressure, they should have used the metal crimps. Highland Audi however did not have any crimps so they cleared fault codes and told me to take it RS6 back to Fife Seat when I got home.
Light reapeared, as advised went back to Fife Seat who this time decided to change yet more hose and replace the valves, remember, these had been confirmed as working ok by Highland Audi.
One month later same fault back, Fife Seat decided to clean out EGR valves and change diapragms and advised that if this did not cure problem they would have to replace the EGR valves and take cylinder heads off, they assured me that this was the advice that Audi technical gave them?????
Three months later this time same fault codes, advised that cylinder heads would have to come off, told dealer to take a run and jump and went to Star performance in Dysart for a second opinion. With in 30 minutes they diagnosed the fault as the secondary air pump had no output, new pump fitted and I have had no further problems since.
Moral of the story is do not trust Fife Seat with your Audi, they are completely incompotent. I have other stories to tell about Fife Seat but I am in the process of involving Trading Standards so will tell all when I have the full story to tell
MountainMutant
MountainMutant
You can remove the filter from the top of the pump and clean it. Who knows, it may work.
MountainMutant
Users browsing this forum: No registered users and 210 guests
