Some propper errors C5 RS6 :)
Posted: Fri Oct 23, 2009 7:26 pm
Got the following errors on VAG-COM
Any help would be greatly appreciated.
Friday,23,October,2009,19:47:23:51263
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WUAZZZ4B44N900652 Mileage: 83380km/51809miles
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558 B
Component: 4.2l V8/5VT G 0002
Coding: 0005752
Shop #: WSC 00000 000 08192
3 Faults Found:
17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 008 - Implausible Signal - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 03203
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 03203
1 Fault Found:
01200 - ABS Valves Supply Voltage
35-00 - -
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 07918
Shop #: WSC 01310
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
01141 - Luggage Compartment Unlocking Switch (E165)
29-00 - Short to Ground
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02195
1 Fault Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 Q
Component: symphony II NP2 0400
Coding: 00201
Shop #: WSC 01280
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Part No: 4D0 907 273 C
Component: Reifendruckueberw. D310
Coding: 22350
Shop #: WSC 02195
2 Faults Found:
01477 - System Switched Off
35-00 - -
01521 - Sensor for Tire Pressure
53-00 - Supply Voltage Too Low
76 77
Coding: 0005752
3 Faults Found:
Coding: 00001
Shop #: WSC 03203
1 Fault Found:
Coding: 06697
Shop #: WSC 03203
1 Fault Found:
35-00 - -
Coding: 07918
Shop #: WSC 01310
5 Faults Found:
35-00 - -
Coding: 00101
Shop #: WSC 02195
1 Fault Found:
35-00 - -
Coding: 00201
Shop #: WSC 01280
1 Fault Found:
Coding: 22350
Shop #: WSC 02195
2 Faults Found:
35-00 - -
