Where to buy longer grille after removing fog lights ?
Posted: Fri May 29, 2009 9:44 am
by albertpl
I'm looking for longer air guide grille after removing the fog lights.
Where could I buy the parts like on the pictures bellow ?
RE: Where to buy longer grille after removing fog lights ?
Posted: Sat May 30, 2009 3:51 am
by ataRS6
give MRC a call they supplied me with mine
Posted: Sat May 30, 2009 9:06 am
by albertpl
e-mailed Lucas @ MRC. I will see what will be the response.
Posted: Sat May 30, 2009 8:55 pm
by mattler
Why would you do a thing like that?
Not a dig, just curious
Posted: Sat May 30, 2009 9:02 pm
by albertpl
When you take the fog lights + plastic around it the intake temperature drops down 10-15 degrees Celsius.
I came to this after analysis of VAG-COM and the intake temperatures together with engine ignition <beep>. The ECU is not moving back the ignition that much now. The tests where conducted in several runs 0-200km/h or 60-160km/h.
Posted: Sat May 30, 2009 9:23 pm
by mattler
So basically more performance or throttle response. Intersting! May do this myself.
Matty
Posted: Sat May 30, 2009 9:48 pm
by albertpl
the air that gets to the cylinders has certain temperature, the lower the temperature the better engine runs giving more power
the air on standard RS6 + chip is 40 up to 65 degrees Celsius
so taking out the fog lights + the plastic lest more air to the intercoolers thus cooling them down more
Take a look at Sportec RS600 car and the parts that come with Sportec Intercoolers
The easiest thing is to test that with VAG-COM and wath the intake temps.
Posted: Tue Jun 02, 2009 11:32 pm
by GardinerG
I am interested in these as well.. ;-)
Posted: Wed Jun 03, 2009 1:10 am
by p3u
I'd like a set as well! Keep us updated!
Posted: Wed Jun 03, 2009 6:51 am
by albertpl
No luck at MRC. Lucas did not reply :(
I'm looking still ...
