Page 1 of 2
????Whining noise on boost????
Posted: Sun May 03, 2009 3:50 pm
by BigMo
Thought the car was a tad bit jumpy today. Wound the windows down and could hear a whining noise when on full boost. Turbo up the spout? Anyone?
RE: ????Whining noise on boost????
Posted: Mon May 04, 2009 3:15 am
by BigMo
46 views and bump!!!! Anyone????
Posted: Mon May 04, 2009 7:26 am
by Cornishmoocher
Not sure Mo, When my box went tits up it whinned like a bugger and obviously got worse the harder you pushed her. Could be a pully or tensioner. Or it could be your turbos. I know what i would do mate. I wouldnt be taking a chance, i'd head back to MRC to get them to check it out just in case it is a potential terminal problem, and hopefully catch it before it does go mahoosive.
Posted: Mon May 04, 2009 10:19 am
by BigMo
my thoughts exactomondo fella. Cheers.
Posted: Mon May 04, 2009 2:18 pm
by BigMo
Bugger!!! Now the switch from 1st to 2nd is lumpy!!!!!
Posted: Mon May 04, 2009 6:23 pm
by drybeer
then I feel sadly the 'box is donald ducked. Mine also made a turbine- whine when it became faulty.
Posted: Mon May 04, 2009 6:57 pm
by BigMo
It's all going pete tong!!!! What next?
Posted: Mon May 04, 2009 7:02 pm
by Cornishmoocher
Before you go getting morbid about your box..... Get the chaps at MRC/whoever you use but believe its MRC, to do gearbox oil change serivce.
When I had my box changed by Audi under warranty, the numpties left all the bolts in the sump apn loose. I was losing oil all the while. Eventually the box started to slip and whine. Emergemcy trip to Grizzly and after tightening up the bolts and addeing 4 or 5 ltrs of ATF, the thing has been right as reign ever since...... Its worth a try.
If you are covered by a warranty and your box has not been changed, it may well be worth doing it anyhoo, but just remember to get MRC to do it, that way you wll get to keep your box map AND the job will be done properly. (as a rule Audi will change the TCU too)
If you don't normally use MRC for this type of work, I would go to them or Grizz, I know Grizz has done laods of warranty work and the warranty boys know and trust him. I am sur MRC are in a similar position tho.
Cheers Mooch
Posted: Mon May 04, 2009 9:12 pm
by BigMo
I'll drop by Doug's over the next couple of weeks. The problem is more prominent when using the loud pedal, under normal driving conditions seems ok. Cheers for the advice chaps.
Posted: Tue May 05, 2009 4:22 am
by Doug_S2
Time for a health check i think.
Posted: Tue May 05, 2009 9:59 am
by BigMo
anytime over the next two weeks Doug me old insomniac?
Posted: Tue May 05, 2009 10:17 am
by Doug_S2
shoot lucas a call and he'll find a slot. Those monday mornings (tuesday on bank holidays) i come into work early.
Posted: Fri May 08, 2009 9:08 am
by BigMo
Booked for Monday!!!!!!!
Posted: Tue May 12, 2009 2:13 pm
by BigMo
She in the capable hands of Dr Doug and Dr Lucas!!!!! Pray!!!
Posted: Tue May 12, 2009 5:47 pm
by MartynC
Our thoughts are with you at this difficult time Mo.
MartynC
