Outside temp reading???
Posted: Sat Mar 14, 2009 6:26 pm
by ecain63
My outside temperature reading was a bit skewiffy today. Reading 18 - 25 degrees when it was obviously not that warm. it did drop to around 15 when driving sensibly, and went up to around 28 when driving hard. im guessing it must be coming into contact with something warm (radiator / hose etc), or its gone belly up.
where is the sensor located? i'd like to see if it had been moved by accident.
RE: Outside temp reading???
Posted: Sat Mar 14, 2009 6:27 pm
by ecain63
I say 'my' outside temp reading, what i meant was 'the cars' outside temp reading. lol
Posted: Sat Mar 14, 2009 8:18 pm
by Daveperc
Mine has this problem too - always has. Generally reads about 3 degrees over what it should. Works OK at high speed, and shoots up when statioary.
I assume it's just sited too far under the bonnet somewhere.
Dave
Posted: Sat Mar 14, 2009 9:02 pm
by Rilla
as far as i know the sensor is situated just behind the front bumper, near the grille around the fog light. Problem is the RS6 generates so much heat soak that it is just picking up heat from the engine.
Posted: Sat Mar 14, 2009 9:37 pm
by ecain63
it didnt do it till this morning. i'll have a look to see if its come off its mount or something.
Posted: Sun Mar 15, 2009 7:26 pm
by tartan_rob
I found mine to the right hand side of the centre grill. My bracket was broken to I relocated mine under the car. That way there is little or no heat soak. I have dumped the oil cooler housing that the temp sensor plugged into and created a CF scoop that flows more air into the oil cooler. The fact that I did this ensured I had to move the sensor.
Posted: Sun Mar 15, 2009 8:24 pm
by ecain63
where abouts exactly in the centre grill. am i blind? i cant find it.
Posted: Sun Mar 15, 2009 8:45 pm
by ecain63
Ah! Is it the brown nipple thing that looks like a radio active material badge? the really non-air sensor looking thing that pokes through the plastic piece surrounding the cooler? Mine was still in place, and looks in good nick. Maybe its internally dead?
Posted: Sun Mar 15, 2009 10:03 pm
by SteveH
I had mine replaced, a cheap and simple fix
Posted: Mon Mar 16, 2009 10:17 am
by ecain63
i shall investigate to replace!!
