Central Locking - Factory Coding?
Posted: Fri Jan 02, 2009 10:24 am
by rs-mad
Hi,
Would like to know the factory coding for a Sedan Euro Spec RS6 (RHD) for the central locking module.
Thanks in advance.
RE: Central Locking - Factory Coding?
Posted: Fri Jan 02, 2009 11:52 am
by WeaselRS6saloon
I had mine replaced under warranty because the auto lock on drive off wasnt working, the part number is 4B0 962 258 N,
hope this is what you are looking for........
Posted: Fri Jan 02, 2009 11:55 am
by rs-mad
Weasel - Thanks, but that is the part number I require the soft. coding of the actual unit.
Posted: Fri Jan 02, 2009 12:02 pm
by WeaselRS6saloon
Hi, sorry.......
maybe this thread will help on page 2,
http://www.rs246.com/index.php?name=PNp ... sc&start=0
Re: RE: Central Locking - Factory Coding?
Posted: Fri Jan 02, 2009 6:06 pm
by HYFR
WeaselRS6saloon wrote:I had mine replaced under warranty because the auto lock on drive off wasnt working, the part number is 4B0 962 258 N,
Is auto lock a standard factory setting ?
Mine doesnt auto lock and I just thought it needed to be vag com'ed for that (did it on my old TT) . . . I've got warranty so would gladly get Audi to cough up some more doh.
The light on the button doesnt work . . .
RE: Re: RE: Central Locking - Factory Coding?
Posted: Fri Jan 02, 2009 6:46 pm
by WeaselRS6saloon
Yep, it is set via Vag Com,
trouble is I was told all A6's circa 02-03 had a problem with the control module where it would play up and stop working.
I had a right game with the Audi dealer and they denied any knowledge of the problem, I printed off loads of threads from off this site and took it into Audi and they eventually sorted it out, but you need to make sure that if you need a new module it has the latest firmware in it vD38 and not vD37.
If you need a new module Leicester Audi told me that 4B0 962 258 N is the right part number for a module with vD38 in it if other people had the same trouble.
Posted: Sat Jan 03, 2009 3:37 am
by rs-mad
What I actually require is the coding number that you see via Vag Com, if someone could do a quick scan and tell me that would be awesome!!!
