Another DRC failure
Posted: Tue Nov 11, 2008 2:04 am
This may be quite a long post so apologies if I ramble on………
Before spending My hard earned cash I did quite a lot of reading up on this forum to see what I was letting Myself in for so was aware that the DRC (amongst other things) was potentially a big problem.
When I found the right car (in March) and took it for a test drive (mostly on reasonably smooth tarmac) the suspension seemed a little firmer than I'd expected from My previous RS6 drives but they were Saloons so I thought maybe there's a difference in the ride between Saloon and Avant.
On checking over the paperwork I noticed that the last time it had been in to the dealers they had advised that Two of the shocks were showing signs of leakage.
Of course it was Saturday Afternoon so I couldn't try to find out how bad it was by talking to them and after an Eight Hour Train ride to go and pick it up I didn't want to go home alone.
So as the car still had Six months Audi extended warranty left on and haggling the price down a bit more I drove home (well to Leeds actually to see My folks then back to Cornwall the next day).
I noticed on the drive home and in the following days that at almost any speed, hitting any sort of uneven surface resulted in clonking noises from the rear sounding like the battery was loose, (sounds familiar?) and worse it felt like the back end would jump to one side at speed.
I took it to my local Audi Dealers (Truro) who test drove it and said they thought it was fine and the noise was probably a front ball joint.
I have a friend who has just installed a one man mot test lane in his garage which has pneumatic shaker plates for testing front suspensions and he could find nothing wrong.
But while it was up in the air I noticed a transmission fluid leak (I was expecting this as I had noticed a few spots on the driveway).
So I went back to the dealers for them to investigate and asked that they remove the wheels to inspect the shocks.
I went to pick the car up and sure enough all four shocks are leaking, so much for nothing being wrong.
The good news is that they are did all the work (all Four shocks and a new transmission sump gasket, filter and fluid) under warranty.
The bad news was even though I explained to them that the job will not be satisfactory unless they replace both the valves, they refused to replace them (unless I paid for them) as they say there’s no sign of them failing.
They did the work and it didn’t really cure the problems.
So I took it back again and took their supposedly top tech for a ride and tried to find some poor road surface to reproduce the driving conditions that I have to drive on every Day (the roads in my area are pretty appalling and full of pot holes) and after a 20 Minute test drive he “diagnosedâ€
