Cruise control packed up ??
Posted: Mon Aug 11, 2008 7:26 am
by g338iry
Anyone had any probs with cruise ? Checked fuse all good.
RE: Cruise control packed up ??
Posted: Mon Aug 11, 2008 1:15 pm
by GardinerG
Hi g338iry, I would find someone local to run a full fault scan with VAG-COM or similar.
Where are you based?
Posted: Mon Aug 11, 2008 6:14 pm
by andyt
I had a problem with the CC on my S4. It would entirely stop working until I pulled over, stopped the car, took the key out and then started it again (which was a PITA on the M62
). It turned out to be a fault with the controller stalk whereby if I pushed the speed+ button anything more than gently it would trigger an implausible signal and cancel the CC. This showed up in a vag-com scan IIRC. In the end I just learned to live with it!
Posted: Sat Aug 16, 2008 11:56 pm
by estrop77
mine used to stop working if I used my indicators. cruise stalk replaced under warranty by Camberley Audi. all sorted.
