Big Brake Upgrade
Posted: Wed Jul 30, 2008 10:38 pm
by DrB
Just picked up my car from www.mrctuning.com
Just had the brakes refitted including an upgrade to 390 x 36mm (new RS6 disc size) for the fronts. I have attached a picture of the difference in discs.
Thanks very much to Lucus, Doug and guys there.
Mark
RE: Big Brake Upgrade
Posted: Thu Jul 31, 2008 5:52 am
by Pau1
Very nice. I was contemplating this upgrade when a pair of the above discs were delivered at Unit 20 last month. I'll have to come round and have a look at them all fitted.
Posted: Thu Jul 31, 2008 8:12 am
by grizz
It's a good cheap up grade on the rs6 . We've done several kits .
Posted: Thu Jul 31, 2008 8:55 am
by R1NGA
Grizz,
I've PM'd you about thee - just after prices if that's OK. Running std 19" alloys.
Thanks,
Phil
Posted: Fri Aug 01, 2008 7:08 pm
by foz01
how much is it?
Looks like my discs and pads are on thier way out..
Posted: Sat Aug 02, 2008 8:33 am
by Pau1
PM Grizz mate. He'll sort you out. Also, i've sent you a PM on Eastside about a trackday at Knockhill on the 30th.
Posted: Mon Aug 04, 2008 10:25 pm
by supercopa
nice upgrade but what about the pads? are the standard ones large enough ?
Pau1 looking to your signature... seems we have some "things" common around there... ;)
Posted: Thu Aug 07, 2008 11:19 am
by Spacecowboy
it looks very great !
what parts do you need for this upgrade ?
the c6 discs and break pads ? the rest can be stay original ?
Posted: Thu Aug 07, 2008 12:09 pm
by Nige_RS4
Daniel, you need a bespoke 5mm hub spacer that goes between the disc and original hub IIRC.
Grizz can supply these (I'm sure MRC can too!)
Posted: Thu Aug 07, 2008 12:19 pm
by Spacecowboy
thanks for the fast answer !
it is even easier to use the c6 brake calipers ? will that work ?
ok, it is expensiv, too !
Posted: Mon Dec 29, 2008 3:14 am
by Rino
Are those a direct fit on the RS6? Do you have a Part No?
Thanks!
Posted: Mon Dec 29, 2008 8:53 am
by grizz
Sorry they are not a direct fit , you need a "kit" to make them fit .. Grizz
Posted: Mon Dec 29, 2008 1:13 pm
by Spacecowboy
hello grizz...
can you present your full kit here ???
pics are welcome...;-)
Posted: Mon Dec 29, 2008 6:47 pm
by Rino
Yes! that would be great......
