Knocking noise from the rear drivers side?!?!?!?!
Posted: Thu May 08, 2008 9:27 am
by bigfra
As title,getting a knocking noise from the rear of the car and i think it's coming from the driver's side!It only happens after ive been driving for a while and it's starting to REALLY do my tit's in!!
Any idea's lad's?
Fraser :(
RE: Knocking noise from the rear drivers side?!?!?!?!
Posted: Thu May 08, 2008 9:33 am
by GardinerG
Does it sound like it's coming from the inside or outside? It's not the exhaust knocking against something is it (it expands when hot)?
Posted: Thu May 08, 2008 9:38 am
by bigfra
Hmmm,good question.Im sure it's coming from the inside but when i stop the car and bounce the back up and down i can't here ANYTHING!It's a Milltek exhaust that's on it so would that make a difference??
Posted: Thu May 08, 2008 2:49 pm
by grizz
When the milltek gets hot it expands, it can knock if not fitted wright.
Posted: Thu May 08, 2008 4:37 pm
by HyOctane
You should not be able to bounce the car up and down. Sounds like the dreaded DRC failure has been wretched upon you.
Posted: Thu May 08, 2008 4:50 pm
by bigfra
HyOctane wrote:You should not be able to bounce the car up and down. Sounds like the dreaded DRC failure has been wretched upon you.
I have Billstein coil overs on and i don't mean BOUNCE as in bounce,i just mean it doesnt knock when i move it up and down at the back!
Posted: Thu May 08, 2008 7:45 pm
by skiwi
i take it is not a rythmic knocking, rather than intermittent?
suggest exhaust (check by wiggling the tailpipe when hot) or cat.
Posted: Thu May 08, 2008 8:18 pm
by grizz
It could be a anti roll bar link .
Posted: Thu May 08, 2008 8:44 pm
by mattysupra
as grizz has just said! That would be my guess!
Posted: Thu May 08, 2008 9:28 pm
by SteveH
I had an anti-roll bar bolt fail ages ago, that knocked... simple bolt and all was good.
Posted: Fri May 09, 2008 8:13 am
by bigfra
Thanks lad's.ill give all of the above a try!!
Fraser :D
Posted: Fri May 09, 2008 10:54 am
by R1NGA
Almost certain to be the exhaust hitting the rear subframe, where the pipe does its dogleg. Mine does exactly the same and I will eventually get round to having it bent a little further to correct it. Think I have a slightly inaccurate midsection pipe.
Phil G
