Suspect Abnormal Tyre Wear - RS6 Front Tyres
Posted: Wed Apr 16, 2008 11:45 pm
Hello fellow RS6 owners!!
I'm new to the whole RS ownership excitement, but needless to say I hope you all love your cars like I do. The only way I could afford one was to remortgage the house to free up the cash. Needless to say, after stumping up a hefty sum and then parting with it at my Audi dealership, I'm a tad miffed to be arguing with them already about trying to get a problem sorted. Therefore, I'm casting the net out amongst you all, to see if any of you have had similar tyre problems and can offer some advice.
I don't believe it the tyres on this occasion, so I need to resolve the route cause of a problem, which I believe is as a result of abnormal tyre wear caused from a misalignment issue of my car's geometry. The car is an Audi RS6 Avant 2004 model.
Breif History -
I decided to abandon having an MOT with my dealer today, straight after I noticed excess tyre wear. The innermost edges of my car's tyre walls, which are normally out of sight under the wings, are actually down to the canvas, even though the remainder of the tyres surface area are generously above the tyre wear indicators. Please refer to the 'offside' & 'nearside' photos attached to visualise and help understand the concerns I have.
I'm the second owner of this car and therefore, haven't been party to the cars entire background to understand if this is an ongoing problem, either mechanically or by it's inherent design. However it has bought, serviced and maintained through the same dealer I bought it from. I asked them to have a look to see if there were any obvious issues causing it, but in short, I was told that this needs to be addressed at my cost. I have a comprehensive warranty and I persoanlly think that covering just 3000 miles since it's MOT 11 months ago when I bought the car from the Audi dealer, that this is unacceptable. I want them to inspect and repair the car under warranty, if they find that the wear is due to a steering fault, or tracking issue.
I'm am however, trying my best to be impartial with my dealer at present, as I've decided to gather more evidence from both Michelin and other RS6 owners before I try and argue my point any further with them.
Question 1 -
My dealer hasn't yet put the car on the alignment gear, but they are suggesting, that this wear is due to the cars camber setting on this vehicle, which is due to its perfomance and cornering geometry set-up. However, I think that if my dealer's opinion was right, the wear would then appear as a more gradual taper across the profile, starting from the exposed canvas and working out towards the opposite side of the tyres profile. If you look at the pictures, then if this were true, surely there wouldn't be such a consistent depth across the 3 centre channels and either side of it? The photos show that the tyre wear is almost up on the sidewall rather than the main contact patch area of the tyre during normal use.
I guess you can probably judge that my driving is far from erratic during cornering, as the outer edges of the tyres are not abnormally scuffed down to the point where they would get loaded up during cornering on the outside walls if I were driving fast into bends.
Question 2 -
I pay great attention to making sure the tyre pressures are accurate to the manufacturers recommended settings and this car benefits from an active monitoring system, so I've not driven the car with incorrect pressures. I don't believe this wear is a result of running excessive pressures (as the centre wear would be more pronounced). Alternatively if they were underinflated, I would imagine that both of the outer sections would display more of a wear mark across a larger area and of course the car would warn the driver accordingly.
My dealer wants me to change the front tyres before they will perform the geometry check / 4 wheel alignment, however, my reservations are that I would rather understand from you what may be wrong, before putting more wear and tear on another new set. I'm also worried they may just charge for one test after another just to provide me with answers based on their opinions, which may be different to your own.
Question 3 -
Finally, are the current Michelin Pilot Sport 2's fitted to my car when I bought it, the right tyre for this car?
I look forward to any comments that any of you may have and ideally any of you that have had similar wear, if you could advise what the problem is, I'd be very grateful if you could give me some guidance.
Happy motoring and kindest regards,
Chris Webb
Breif History -
Question 1 -
Question 2 -
Question 3 -
Chris Webb
