RS6 Oil Spec
Posted: Sun Feb 03, 2008 7:04 pm
by Rob1977
Please can someone tell me what spec codes Audi list in the handbook for the oil on an RS6?
RE: RS6 Oil Spec
Posted: Mon Feb 04, 2008 8:14 am
by skiwi
while audi specifies that any oil which meets or exceeds vw 502 00 will fit all their cars - the rs6 is a special case, and a special technical bulletin was issued to cover it.
in the case of the rs6, only oil which conforms to vw 505 01 with viscosity of 5w40 will do. audi warn that failure to adhere to this can result in engine failure.
RE: RS6 Oil Spec
Posted: Mon Feb 04, 2008 9:15 am
by rs-mad
I have run Motul 5W40, Castrol Edge 10W60 and currently run 5W30. Motul was the best but as i change it every 5000kms it cost very costly
RE: RS6 Oil Spec
Posted: Mon Feb 04, 2008 2:03 pm
by dace
Synta Gold 5W40 and change every 4,000 miles IMHO
Re: RE: RS6 Oil Spec
Posted: Mon Feb 04, 2008 7:22 pm
by Rob1977
skiwi wrote:while audi specifies that any oil which meets or exceeds vw 502 00 will fit all their cars - the rs6 is a special case, and a special technical bulletin was issued to cover it.
This car shows up on Audi system as being on longlife servicing,is longlife not reccomended for this engine at all? as the 505.01 is fixed servicing oil.
RE: Re: RE: RS6 Oil Spec
Posted: Mon Feb 04, 2008 8:07 pm
by Rupert
The RS6 is not eligible for AVS.
Posted: Tue Feb 05, 2008 9:19 pm
by skiwi
the rs6 is an exception, and is on fixed intervals...
just to re-state only 5w40 is recommended by audi. in the strongest possible terms....
Posted: Tue Feb 05, 2008 9:24 pm
by grizz
I use MILLERS 10W60 , This will give a much higher level of protection when the oil is hot..
Posted: Wed Feb 06, 2008 12:29 am
by skiwi
it is interesting that audi specify a lower viscosity synthetic oil - i would have assumed high temps was more of an issue - not audi.
Posted: Tue Feb 19, 2008 10:04 am
by marmite
I was under the impression when they released the RS6 the approved oil was Mobile 1 which is what we use on the porsche 0w 40 VW 505 00/502 00 I maybe wrong though
Posted: Tue Feb 19, 2008 7:16 pm
by skiwi
yes it is, but only the 5w oil, not the 10w one.
