Clutch Slip?
Posted: Tue Aug 21, 2007 11:00 pm
by Shaggy
Not been around for a bit. I got rushed into hospital a couple of weeks back with Ruptred Appendix :)
Took the car out for the first time today since the opp. On the way home, turning into my road I accelertaed but there was not gear, just a scream, then the gear caught hold.
Any ideas?
RE: Clutch Slip?
Posted: Tue Aug 21, 2007 11:04 pm
by s4woody
low on fluid..or massive wheel spin..hope your feeling better now..
RE: Clutch Slip?
Posted: Tue Aug 21, 2007 11:08 pm
by Rupert
I have no idea, but I'm glad you're back in the saddle again.
I had wondered about your lack of posts.
Hope all is well now.
RE: Clutch Slip?
Posted: Wed Aug 22, 2007 8:31 am
by marmite
Glad to hear you are ok mate:)
Mine was doing that after Audi didn't put enough oil back in my gearbox and left the seal off the filter inside the box.
Have a look if she is leaking oil or not.....or you were pushing her to hard???
RE: Clutch Slip?
Posted: Fri Aug 24, 2007 1:19 am
by Shaggy
Nah I were not pushing. I was turning into my road, I accelerated quickly, but not hard.
RE: Clutch Slip?
Posted: Fri Aug 24, 2007 9:12 am
by skiwi
wet or slippery conditions? did the traction control engage?
RE: Clutch Slip?
Posted: Fri Aug 24, 2007 12:09 pm
by W8PMC
Hate to be the bearer of possible bad news, but that slipping was the 1st warning for both times my Gearbox failed & needed replacing.
Symptom was accelerate from very low speed or even standstill & the revs would rise to say 3000ish RPM but no real traction/drive, then all of a sudden BANG & drive engaged & the car lunged forwards. This over the period of say 2-3wks got more frequent from it's initial appearance until the ECU decided the gearbox was fooked & then locked the box into limp mode (3rd gear).
Hope this is not the case with yours, but the symptom is near identical.
RE: Clutch Slip?
Posted: Fri Aug 24, 2007 2:42 pm
by 42tt
I strongly recommend checking fluid level aswell as leaks.
42tt
