Radiator leak
Posted: Tue Jan 30, 2007 7:29 pm
by alangjones
RS with 59K. Just been told there is a water seep from a side seam on the main rad. Will need to be changed at next service in 3K miles. Anyone else had this problem. ?? A warranty prob or my pocket and any idea of cost? Re susp my dealer replaced all fluid and repressured cost £200 and post replacing of 4 shocks and a DIC ?? valve on extended Audi warranty
RE: Radiator leak
Posted: Tue Jan 30, 2007 11:23 pm
by bbigman2000
Repressurising is not possible !! They are having you on mate !!
But if the cars fine, no shady handling then fine.
As for the Rad, that should be under warranty unless it was stone damage.
Posted: Wed Jan 31, 2007 11:33 pm
by alangjones
Thanks. I thought the struts were diagonally opposed and had DRC? valves controlling fluid. When a strut leaks it loses fluid and needs replacing and the diagonal link osf/nsr and vice versa is by pressurised fluid system with ??16bar. When units and DRC changed air can be trapped in the system so the rattling/banging on rough roads returns. The only way to correct is to replace the oil in the system and repressurise?? Also the headlights are linked to how this system reacts .I think there are 'motors' front and rear controlling how the H/L adapt. When my susp/DRC went t-ts up the headlamp warning lit. Motors were replaced and all well until this air problem when H/L adjustment fault recurred and with the refill etc all back to normal. Oh for twin SU's and a stethoscope for tuning and kingpins at the front, with a feeler gauge for points. Yup 0 - 60 in 25 secs or 23 secs on Cleveland Discol but it was all soooooooo simple! Its also a b-gg-r being old!!
Posted: Thu Feb 01, 2007 12:13 am
by bbigman2000
Your right they are, but when they change suspension components they should change the pressurised valve also.
Posted: Thu Feb 01, 2007 2:06 pm
by alangjones
They did replace the valves and I was told it was a b-----d to do. As they were fairly inaccessible and not meant to be changed. They said it was ''known''.
