RS6 on track - brake wear is really tough (pics)
Posted: Wed Mar 01, 2006 12:44 am
So have taken the 6 on track 3 times and the summary is....
Great fun, bit not its natural environment...shocker!
Seriously the shear weight of the thing handicaps it. The understeer is substantial. Try lifting the bonnet then stand exactly square with the centre cap of a front wheel....you'll see how far forward the engine is. Not a single inch of that huge, heavy muther is behind the center point of the axle. Its like a 911 in reverse! Amazing it handles so well given this setup. JR and Simple1 did this at Combe, they will testify how far forward the engine is.
Anyway, the biggest issue is the ability of the brake setup.
I have done Castle Combe twice and Donington once in the 6 and have done two sets of pads.
At the last day at Combe the last session I did was about 8/10ths (more than my previous limits). I had some great instruction from Colin (profile Instructer) really made a difference. But putting a near 2 tonne car at 140mph into Avon then braking to 45-50mph before Quarry is unrealistic given the brakes get about another minute track usage before repeating this corner.
So I actually was easier on brakes than in the past as I had climbed the learning curve and got over the novice go fast as I can, brake as late and as hard as I can, and with Colin's help learnt to carry speed into corners, wait until the car car geometry/dynamics were ready before giving it some V8 wallop
But still I crucified a set of pads....
These pads were only 3k miles old when the track day commenced.....
Every one of them is cracked down the centre. And about 3/4 depth taken out of them.
On the day after the last session I thought I had disintegrated the pads and scored the discs....however...
After a visit to Auto Performance Services on Monday (they prepped the car for the trackday) it transpires I have fecked the pads, but not the discs.
Nathan is the Workshop Manager there. I have the utmost respect for him, so much experience and knowledge. He took one look at my brakes and told me the discs were fine (phew that saved me £600).
Basically the pads had got to such a temp that deposits had 'molten' and then been distributed on the discs. When the deposits cooled they'd solidified and gave the appearance of ridges in the discs. Leaving me with the impression the discs were grooved and needed skimming or replacing. Thankfully my impression was incorrect and the new pads removed the deposits and all is well.
But the bottom line is the RS6 is a significant piece of kit to take on track and the consumables make it a VERY expensive day out.
Tyres are another issue. I have Demon Tweeks costing a set of wheels and Toyos at approx £1k, but they reckon I'd only get 3 trackdays from the set of rubbers.
So time to get a track car. I am going to follow simple1's route and get an Exige
In the meantime, no more trackdays in the 6. But I will be doing the 'ring in May if anyone is up for that
APS ( www.autops.co.uk ) have sourced me a set of pre-market pads for testing. If these prove fit-for-purpose they will be released for retail purchase and will be significanlty cheaper than the OEM (Pagid) pads. I will keep you posted
FWIW pics of discs and pads.....check out the the grooved appearance and the wear levels...these pads were as good as new at the beginning of the day
