tire mobility system
Posted: Tue Feb 14, 2006 9:45 pm
by whispers
hi ,
had to use TMS stuff in boot as had nasty puncture today .
has anyone had to replace it before ??
should i buy another bottle from audi or best to source elsewhere ?
any help would be greatly appreciated
Chris RS6 avant
Posted: Sun Feb 19, 2006 11:44 am
by MartynC
I'd buy from Audi. Did it work?
MartynC
Posted: Sun Feb 19, 2006 5:02 pm
by whispers
it worked a treat , took the valve out and let what little air their was out and really had to squeeze it in hard , blew it up with the compressor to 36psi then drove it on and off the drive .
did this in the afternoon and 24hrs later it was still up no problem when i had the tyre replaced as it was low tread anyway.
one thing to note it took them a while to get the tyre off as the gluey stuff had set solid , so yes its good , but for a simple puncture it may not be possible to repair when you use the TMS in the boot
picked a new bottle up from audi , took 24hrs to get and cost £30 .
Chris
Posted: Thu Feb 23, 2006 11:29 pm
by Jeeves
Don't know if the Renault stuff's the same, but since my Clio came with 2 bottles of it and I can fit a spare aftermarket wheel in the normal underboot space, I'm reserving the Renault gunk for the RS if I ever need it.
I guess Renault stuff should be cheap, assuming its as effective.
Posted: Fri Feb 24, 2006 12:07 pm
by SimonS4MTM
And your pressure sensor, was it knackered????
Posted: Sun Feb 26, 2006 3:52 pm
by whispers
yep it was , but fallen out with sensors a long time ago as they were always going off when the tyrs got warm , so replaced them all with normal valves 6 months ago .
Posted: Tue Feb 28, 2006 2:11 pm
by SimonS4MTM
thats because you did not set nominal presures correctly.
http://www.beru.com/download/produkte/k ... _tss_e.pdf
i emailed this link to the crew a long time ago, they obviously did not think it worth while to post it
