RS6 MTM stage II vs S4(b5) stage III super side by side
Posted: Fri Sep 23, 2005 12:22 pm
the question is:bobjebb wrote:cant be right... must be way more than stage three going on there. 505bhp vs 340bhp? C'mon.
Ahh, that makes sense then.rs4imola wrote:The owner of the RS6 said![]()
"That happens to be my RS6 and it was malfunctioning. problem has been fix and the beast is back.
once i toped out at 158mph i knew something was wrong(i usually hit 165mph in no time) and come to find out, the rod that controls the valve in the exhaust pipe( The exhaust system is electronically and vacuum operated to open and close Pierberg bypass exhaust valves)was not functioning, it had poped out which in turn was keeping the valve CLOSED and airflow IN. what an embarresment but <beep> happens. I've informed the s4 owner that whenever he's rdy and has a little cash to spare, i'll come see him down in miami."
will be truth?![]()
cheers
no stage 3 is 340bhp, maybe 340whp which sounds about right.bobjebb wrote:cant be right... must be way more than stage three going on there. 505bhp vs 340bhp? C'mon.
W8PMC wrote:BULLSHIT!!
One of the vehicle models can't be correct.
My guess is that old S4 is very very very heavily modded (520BHP+) & the RS6 is not modified if in fact it's even an RS6. Could be an S6.
I've had my RS6 up against an MTM stage3 RS4 & the result was similar to that on the video clip, only the RS6 was ahead.
OK, fair enough. It's obvious from the pictures that your S4 is substantially modified, so against a stock RS6 who may or may not have been suffering with minor performance problems, you'd probably have the edge & if drag runs are your thing then you perhaps have an experience advantage as well. Looks like you won fair & square so well done.s4orce2001 wrote:W8PMC wrote:BULLSHIT!!
LOL ok im not saying that you did not do that but see the video even the minor issue, as the owner calls it, i doubt that he would win, either way it might be a closer gap but not beat me. i top out at 183 mph, he says he goes up to 193mph but the race is until one of us hits top end, if you notice in one of the races i video in the second race i toped out at 175+.
W8PMC wrote:OK, fair enough. It's obvious from the pictures that your S4 is substantially modified, so against a stock RS6 who may or may not have been suffering with minor performance problems, you'd probably have the edge & if drag runs are your thing then you perhaps have an experience advantage as well. Looks like you won fair & square so well done.s4orce2001 wrote:W8PMC wrote:BULLSHIT!!
My RS6 is also heavily modified & is putting out close to 545BHP & 503lbsft, also been rolling roaded at 203MPH & been timed at 4.1secs 0-60mph.
You've got a fat car, so well done. Personally these kind of races are best confinded to race tracks, drag strips or airstrips.
So your S4 is roughly double the standard power output. IIRC, the B5 S4 was either 250 or 270BHP depending on its age so if yours is 500BHP+ then that's very heavily modified.s4orce2001 wrote:W8PMC wrote:OK, fair enough. It's obvious from the pictures that your S4 is substantially modified, so against a stock RS6 who may or may not have been suffering with minor performance problems, you'd probably have the edge & if drag runs are your thing then you perhaps have an experience advantage as well. Looks like you won fair & square so well done.s4orce2001 wrote:
just to make sure that you know the rs6 was a stage 2 from MTM.
also we have ratings atleast from the s4 is like 500 hp and 550++ lbs of torque.
