Help Please - Coolant Pipe Burps!
Posted: Thu Feb 13, 2025 6:12 pm
Good evening crew!
I could do with some advice however it seems that this forum doesn't accept videos, so I've needed to learn how to post to YouTube LOL.
Last summer I replaced my SJP, after-run pump and a bunch of hoses and general maintenance. Shortly after doing this work I noticed that I had a bit of a coolant leak, but couldn't find it. Took it to a garage, put it on the ramp and still could not tell where the coolant was leaking. Long story short, it's the coolant pipe from the hot-side of the turbos (during normal operation) going to the after-run pump located under the intake manifold.
You can see the cotton threads burping fluid, so I am assuming the pipe is damaged internally. The pipe sure seemed fine when I put things back together and I tried to replace clips and pipes in the same location/orientation as removed. I guess it is a 22 year old pipe and it does handle the hottest water, so maybe given up
It's possible I have put the clamp on too far down from the end of the pipe (need to check photos) and thats caused this problem?
What would you do? I'm guessing I should lift the intake again and replace the pipe. But how do you even get to that pipe from inside the engine bay?
https://youtube.com/shorts/TRrlA-e54vY?feature=share
It's this pipe circled in green...
Thanks in advance
Craig
Thanks in advance
Craig
