ground wire
Posted: Fri Jan 10, 2025 10:03 am
by markmark
Hi, I have a problem with starting the engine – the symptom is as if the battery is weak, but the battery is new. I figured out that the issue is due to a lack of proper ground connection to the engine – when I directly connect the engine to the car body, I am able to start it. Does anyone know where the main engine-to-body ground connection point is?
Re: ground wire
Posted: Fri Jan 10, 2025 10:53 am
by 111marc111
Look around the starter motor area. Which is uk drivers side.
Look from under the car up at that side chassis leg and there is a large ground connection bolted up to the underside of that chassis leg. 13mm nut if i recall.
In amongst that is a few cables that head down to the alternator and the starter motor.
Under the starter motor just above the sump is a large ground connection to the block. Cap head bolt with 6mm Allen head if I'm not mistaken.
Have a look. If your still struggling I can probably get you pics off mine.
Re: ground wire
Posted: Sun Jan 12, 2025 11:15 pm
by cover99
I had a quick look under mine can see one end at/around the alternator...other end disappears
Could you post up pictures? Thanks Steven
Re: ground wire
Posted: Tue Jan 14, 2025 6:05 pm
by bilko1
It goes from the rear of the starter bracket to the chassis leg above the alternator. I've just removed the alternator as it decided to pack up after doing the cambelt
If you need better pictures I'll get them when its light.
Re: ground wire
Posted: Tue Jan 14, 2025 6:42 pm
by Shoppinit
Re: ground wire
Posted: Tue Jan 21, 2025 4:32 pm
by 111marc111
Sorry for the delay. Not had chance to get near the car. See pics if you havent found them and solved it already
Re: ground wire
Posted: Fri Jan 24, 2025 8:01 pm
by cover99
Thanks for this will have a wee look..... When the wind dies down a bit. Always good to know where they are. Thanks
