Easiest way to turn engine over without start?
Posted: Sun Sep 22, 2024 12:08 pm
by TOPMAN
Hi all
This is going to be any easy question to answer for some, but today I'm struggling to find the answer.
Engine has been sat a while as I have been taking my time with the SJP install. With fluids dropped and various bits changed, I'd like to start the car systematically. I assume it might be easiest to pull the connector for G28, but I can't find where it connects to the loom. Can someone point me in the right direction please :bigblink:
Thanks in advance...
Re: Easiest way to turn engine over without start?
Posted: Sun Sep 22, 2024 12:10 pm
by Shoppinit
Look in the FAQ. There's a procedure.
Posted: Sun Sep 22, 2024 12:11 pm
by Shoppinit
Saved you the trouble:
shoppinit wrote: Oil system pressurising after long time standing
Pull fuse 29 and turn the engine over for about 5 seconds to prime the pump. Put fuse back in and start normally.
It's the last to bottom fuse on the left IIRC.
Posted: Sun Sep 22, 2024 12:12 pm
by Jayjay101
TOPMAN wrote:Hi all
I always pull fuse 29 and 28 and let the oil pressure build up then start the engine
by Shoppinit
You don't need to pull 28. 29 is enough. Also it won't leave any fault codes.
Posted: Sun Sep 22, 2024 12:19 pm
by Jayjay101
Shoppinit wrote:You don't need to pull 28. 29 is enough. Also it won't leave any fault codes.
Thanks mate! It’s only because it stinks of fuel I pull 28
Posted: Sun Sep 22, 2024 2:45 pm
by Shoppinit
Yeah. I suppose if you’re going to turn it over for a lot time that makes sense to pull 28 too.
Posted: Wed Sep 25, 2024 5:03 pm
by TOPMAN
Thanks guys!
Apologies for the late reply, but I took this advice into action immediately. It was very useful, thanks.
Regards
Craig
