Page 1 of 2
Am I being daft. AC/blower query.
Posted: Thu Jul 25, 2024 8:00 pm
by philS2
I noticed this a few years ago, that the hot coolant expansion tank is right next to the cabin air intake.
My AC works but is barley cold and if I turn the AC off and have it on LO, it blows warm air.
I thought I had a shield missing.
I have removed the engine bay seal, for a bit of heat dispersion, but left the bulkhead seal in place.
Anyone else have this?
Re: Am I being daft. AC/blower query.
Posted: Fri Jul 26, 2024 2:14 pm
by skyegtb
Yep, mine only blows very warm air when the ac is off. You can monitor the temp coming out the vents with
Vagcom and mine showed 27 degrees, getting hotter when car was driven hard. Makes for a very uncomfortable cabin. Not sure why it does this, but with ac on it blows as low as 3 degrees in to the cabin.
Posted: Fri Jul 26, 2024 6:21 pm
by philS2
Think I'm going to make a better sheild between the expansion tank and intake, next week.
I'll let you know.
Posted: Fri Jul 26, 2024 6:23 pm
by skyegtb
I would be interested to hear the results
Posted: Thu Aug 01, 2024 4:49 pm
by philS2
So I've made pretty much the same shield as last time, with car washing sponges. I know, not the best.
It seems to help, but, the other day, I drove out the garage with the AC on, (I don't usually do that) and it stayed nice and cool while driving around, which makes sense, as (if I'm right) it goes straight to recirc mode with the AC on, so wouldn't be dragging warm air from around the expansion tank.
So, like some of the other guys on here, I think I'll just use the AC more.
Posted: Thu Aug 01, 2024 4:56 pm
by skyegtb
Yeah, probably the best idea. The AC likes to be used anyway!
Posted: Thu Aug 01, 2024 5:00 pm
by Shoppinit
Yeah, my AC is always on.
Posted: Sun Aug 04, 2024 11:44 am
by Steve2003rs6
Echo the above.
My a/c is always on.
Posted: Sun Aug 04, 2024 9:58 pm
by Foxmeister
Set temp and choose auto, forget about it unless you need t tweak a degree or 2
Posted: Mon Aug 05, 2024 8:42 am
by srichards
Mine is always on in the intelligent recirculation mode.
Posted: Tue Aug 06, 2024 1:46 pm
by Nobby
Whilst I’m sure isolating the inlet box could help, I fear some of the actual problem is the design of the blower housing and routing of air.
I believe as the air comes into the unit it always goes through rhe AC evaprator. If AC is on the it gets cooled down.
Depending on the mixer flaps position air either goes up, down or both ways. If up it goes straight out to the vents. If down it goes through the heater core then to the vents.
I assume that in full COLD position all air should go up, however some of the air actually goes down to the heater element and swirls back round as the flap is after it.
This must heat up the air. Ideally you want a flap before the heater core. Our cars do not have valves in/out the heater core so it’s always got hot coolant though it.
Posted: Tue Aug 06, 2024 1:49 pm
by Nobby
D is the AC evaporator
E is heater core
F is additional heater that most of us won’t have.
Posted: Tue Aug 06, 2024 4:44 pm
by philS2
Good points. Well analysed.
Is that from the Bentley service manual? (or as my mate calls mine, War and Peace).
Posted: Tue Aug 06, 2024 4:49 pm
by Nobby
Yep. Normally quite expensive but you can pick them up cheap second hands sometimes.
Posted: Tue Aug 06, 2024 4:53 pm
by Nobby
I battled my AC for a while. It was cold, but not quite 100% cold enough on very hot days.
It turned out to be the AC expansion valve on my car was a bit blocked (and was maybe in the wrong way round). It actually sits underneath the coolant tank I’d wager that not many people have changed theirs as it’s hidden.
