Brakes-vcds flag
Posted: Mon Jun 10, 2024 2:15 pm
by steve2003rs6
Anyone know what this means.
Re: Brakes-vcds flag
Posted: Mon Jun 10, 2024 2:20 pm
by Shoppinit
Hasn’t found the label file for your ABS controller.
Might be an issue with your
VCDS installation.
Try updating to latest version after uninstalling the one you’ve got.
Posted: Mon Jun 10, 2024 2:49 pm
by steve2003rs6
Cheers Ben. Will give it a go and report back.
Posted: Mon Jun 10, 2024 4:07 pm
by HPsauce
Are you using a genuine Rosstech cable? I've had communication errors like that in the past when using a cheap Chinese cable.
Posted: Mon Jun 10, 2024 5:29 pm
by steve2003rs6
At £450 it better be a genuine cable.
Hpsauce. Last year my wife was “tidying up” and my unlimited vins cable went missing.
So I bought a new one.
Some time later the cable re appeared.
So I sold it on here.
But yes mate. It is a genuine unlimited vins cable and I am using the latest software release 24.5.
Recently had a brake fluid change. Also had new discs and pads fitted all round.So I don’t know if that has anything to do with it.
Posted: Tue Jun 11, 2024 10:13 am
by steve2003rs6
VCDS uninstalled then reloaded.
Same problem exists
Brakes not recognised.
Posted: Tue Jun 11, 2024 10:24 am
by Shoppinit
Have you installed or updated your antivirus recently? Try installing your AV and/or firewall and seeing if you can connect then. Obvs don't use your laptop on the internet without those things running.
Posted: Tue Jun 11, 2024 10:26 am
by steve2003rs6
If I go into control module then select abs brakes the brakes are recognised.
Posted: Tue Jun 11, 2024 10:29 am
by Shoppinit
Sounds like the autoscan settings are off then. Maybe you've checked or unchecked an option. Since you have a genuine cable, you can contact
VCDS support on their forum, too.
Posted: Tue Jun 11, 2024 10:31 am
by srichards
Whenever updating a version of anything it's always worth checking through all the preferences to make sure they haven't been fiddled with. Annoys me endlessly when this happens.
Posted: Tue Jun 11, 2024 11:00 am
by steve2003rs6
It was ok before I updated to version 24.5.
Posted: Tue Jun 11, 2024 12:02 pm
by srichards
Yep. They'll have changed something. It's just a matter of working out what. I'd email them and see if they have had other people encounter the same issue.
Posted: Tue Jun 11, 2024 1:41 pm
by steve2003rs6
Cheers all.
Now onto Ross tech.
