Page 1 of 2
Gearbox oil sump pan corroded
Posted: Fri Aug 04, 2023 11:35 pm
by Swan
Hello - I’m a couple of weeks into rs6 c5 ownership. Car had a health check today and one of the things noted was a gearbox oil leak and corroded gearbox sump pan. No problem, new pan, filter, oil and gasket. However, Audi don’t supply the part anymore.
Can someone provide the part number and a recommendation for going about replacing the pan? What do you all plan to do when yours needs replacing? Can I source them from other manufactures ZF boxes? Are are they specific to the RS6?
Any help greatly appreciated.
Andrew
Re: Gearbox oil sump pan corroded
Posted: Sat Aug 05, 2023 10:37 am
by Steve2003rs6
I have checked the usual contacts in Germany for a sump. So far no luck.
Will try RS Carparts. Update. No luck.
I believe the part number is 077 103 602A. Ref Audi.7 ZAP
Still have a couple of places that are getting back to me.
Is the original sump definitely knackered.
Some years ago a garage told me I needed a new sump. So I bought a new sump. On close inspection it turned out the sump was fine and it was suffering surface rust.
A good clean and powder coating was all it needed.
Posted: Sat Aug 05, 2023 10:56 am
by Astrosquirrel
The part num I found is 01L321358C for the oil sump, but it's pretty much useless since it's NLA and not even Audi Tradition have it.
I second the thought of a good buff, rust protection and powder coating.
Posted: Sat Aug 05, 2023 11:07 am
by srichards
Is the sump pan the same as other vehicles that use the same gearbox? Didn't Jaguar also use this gearbox on something?
Posted: Sat Aug 05, 2023 11:08 am
by Astrosquirrel
I believe A8's used the same GB.
There's one whole GB at rscarparts:
https://www.rscarparts.de/automatikgetr ... s6-4b.html
Posted: Sat Aug 05, 2023 11:47 am
by stuartbarriskell
If the sump is made of pressed steel, I doubt it will need replaced, it can be a more common issue on higher performance bikes as most if not all the engine cases, head, barrels, sump etc are cast from an alloy of one sort or another.
The last one I replaced was a few years ago on ZX10R. It only had surface corrosion, but it looked scruffy, and I picked a split new one up for 25 quid on Ebay.. from Kawasaki, though, part was over 300 quid..so what the hell.
Cleaned the old one up and sold it for 40 quid, lol..
As per advice above, whip it off and inspect it, good clean and a paint will likely do the job.. are they alloy or steel is the question..
Sent from my SM-S918B using Tapatalk
Posted: Sat Aug 05, 2023 2:06 pm
by Steve2003rs6
I reckon it’s pressed steel.
Aluminium doesn’t rust and I think it’s non magnetic.
Also the magnets are attracted to the bottom of the sump
Posted: Sat Aug 05, 2023 2:19 pm
by Swan
Wow - thanks so much everyone. The garage had a look at it initially and raised the issue. I will try and crawl under and have a poke around. It’s got a leak, so I think il get the garage to do the gasket and oil change and have a good inspection while it’s off.
Am I right in thinking there is a replaceable filter inside? Does anyone know the part number for that?
Thanks!
Posted: Sat Aug 05, 2023 3:05 pm
by Steve2003rs6
Indeed it does have a filter. It’s also very important that you use the correct oil.
See the Audi RS6 spec/faq section at the top of the topics page.
Go to
DIY useful info/links
Scroll down and open
ZF service gearbox kit strainer/filter and gaskets and optional oil
Excellent post by Matt.
ZF lifeguard 5 kit ( 7 litres of oil )
Oil/filter/gasket.
There are two types of filter. Long neck and short neck. You want the short neck.
It’s all covered in matts post.
Posted: Sat Aug 05, 2023 3:49 pm
by Swan
Thanks!
Posted: Sat Aug 05, 2023 5:02 pm
by stuartbarriskell
steve2003rs6 wrote:Indeed it does have a filter.
ABOVE
Go to
Oil/filter/gasket.
The very discussion on the RS4 board last month, my oil was done but no filter that I know of. The invoice showed only oils used and a couple of other wee bits and pieces I had done at the same time. Wished I had paid a bit more attention at the time..
Posted: Sat Aug 05, 2023 5:10 pm
by Steve2003rs6
What is the point of doing a oil change and not replacing the filter.
Beggars belief.
It also gives you the opportunity to inspect the magnets for any debris.
A while back I paid a garage to do a oil and filter change. They did a crap Job. So I had to do it myself in the end.
Traced the problem to the filter o ring being a clearance fit in the recess.
Replaced the o ring for a interference fit and all was good.
Posted: Sat Aug 05, 2023 5:28 pm
by stuartbarriskell
Dunno man, they might have done it. If not, the drive train oils aren't due for another 18k, think I'd get the box oil changed and the filter when it's due in next..I'll be asking for a reduction..
Posted: Mon Aug 21, 2023 3:26 pm
by Trailly
Hi Andrew
I got a new sump pan in June for my 2004 RS6 from Tranzap part no. 56.HP.82 it was £280 delivered
https://www.tranzap.eu/product/hp-hard- ... 2/56.HP.82
Posted: Mon Aug 21, 2023 4:30 pm
by stuartbarriskell
What was up with the original..Corrosion too ?
