To give more background, I have just fitted 2 replacement lights to the car. I refurbished these over the winter and replaced the damaged / missing adjuster cogs and re-lacquered the lenses to make them like new again. Both the original lights on the car had the typical missing adjuster cogs and one of them was broken inside and will require gluing to repair.
Anyway, the old lights were adjusted at their max height and just about gave me the beam that I desired, perhaps just slightly low, but just about acceptable. The new lights I just fitted are just about the same, but again totally maxed out on the height adjuster. I have checked everything over on the car related to the automatic height adjustment and everything is in spec and no fault codes are found. The lights always do the 'self levelling' test when turned on and generally everything is normal. For info, I disconnected the self levelling arms on the front and rear suspension and tested the voltage with Vagcom - they both read from a minimum of 0.5V to a max of 4.5V. When the car is sitting on level ground the front voltage is 2.03V and the rear is 1.83V - all within limits. I also tested the headlights moved when these were manually adjusted by raising the car off the ground on my lift, and manually adjusting the arms. I confirmed that the aim would lower and raise depending on the movement of the front / rear arms.
As the bumper is off the car I have played about with the mounting screws to tilt the headlight upwards as much as possible before tightening the screws, but this does not achieve a particularly big improvement. So, is there any way to get these lights to aim higher and possibly allow me to not have them at the max height adjustment all time?
For info, my other car is a 2001 A6 C5 allroad with very similar headlights to the RS6. On that car the manual aim adjustment is approx in the middle and the adjusting screw allows a huge range of adjustment if required. Why are the RS6 lights so different? Is it something as simple as the actual height adjustment screw on the RS6 is shorter than the A6 screw? Can the A6 screw be fitted to the RS6 headlight? Has anyone done this before?
Looking forward to any opinions / advice. Currently I am thinking of stripping down my old RS6 lights and an old allroad light to compare the innards in detail. I will report back with my findings.
