Front Driveshaft Inner Joint
Posted: Mon Feb 06, 2023 12:08 pm
My offside front driveshaft inner boot has perished and deposited grease over the surrounding area.
I've got an SKF driveshaft joint kit on order : https://www.autodoc.co.uk/skf/12273114
And also just a boot kit : https://www.autodoc.co.uk/skf/14583 in case I decide the bearings are all fine. I'll probably do the whole joint though, because I can.
Has anyone done this job? How hard is it?
I am assuming it'll be :
* remove the lower balljoint,
* undo big driveshaft bolt
* disconnect outer end from hub
* then remove inner shield and undo driveshaft bolts
* And I guess the joint is just circliped on at the inner end?
I'll do the upper arms and balljoints at the same time since they need doing and I'll get some Xanax prescribed in advance. Which reminds me, must order the pinch bolts.
