Lemforder Top Arms
Posted: Thu Jan 12, 2023 10:32 pm
by Mɐʇʇ
Is anyone able to confirm the exact lemforder part numbers for the front upper arms please?
Why?
Because if I look up the Audi part number and cross reference it, I get a different set of numbers than I do if I use the AUTODOC and ECP parts lookup against our cars.
So I’m now confused.
Re: Lemforder Top Arms
Posted: Fri Jan 13, 2023 9:06 am
by Shoppinit
Posted: Fri Jan 13, 2023 4:30 pm
by Mɐʇʇ
I did.
Lemforder's catalogue lists
21030 01 as a compatible part with the RS6.
But lemforders Audi x-ref part numbers for this part does not include 8E0 407 509 P
And if I then search for 8E0 407 509 P on the lemforder site, I get lemforder part number
21613 01, which does have the RS6 part number as a cross reference
Both listed as an upper front right control arm.
Any clue?
Posted: Fri Jan 13, 2023 5:11 pm
by Astrosquirrel
Posted: Fri Jan 13, 2023 9:49 pm
by Mɐʇʇ
So you’ve got the ones that cross reference based on part number, not their parts guide. I assume they fitted and all is good with them?
Posted: Fri Jan 13, 2023 9:58 pm
by Mɐʇʇ
Anyway. Ordered. Same ones as you. Thank you.
Posted: Sat Jan 14, 2023 1:40 pm
by Astrosquirrel
Mɐʇʇ wrote: ↑Fri Jan 13, 2023 9:49 pm
Fit like a glove and visually exact match
. I matched them through part # from 7 zap and AutoDoc. Look also the same as the ones on my 2003 RS6 donor.
Posted: Sat Jan 14, 2023 10:16 pm
by Mɐʇʇ
Yeah, I always use part number x-ref, but this time came up with different numbers, which was odd. Anyway, all on order and looking forward to wrestling with the pinch bolt
Posted: Sun Jan 15, 2023 1:50 pm
by Astrosquirrel
In my experience the easiest way to remove the pinch bolt if stuck is:
1) Cut it as close as you can to the housing
2) Drill a hole in the center of the bolt
3) Air hammer it out with the pointy bit
Good luck
Posted: Tue Feb 21, 2023 6:17 pm
by Mɐʇʇ
All done with the lemforder arms as listed above. Also did the front ARB drop links at the same time - and as above, lemforder are the OEM (Audi logo is ground off). I got the drop links from ECP:
https://www.eurocarparts.com/search/610441165
https://www.eurocarparts.com/search/610440935
