Lemforder Top Arms
Lemforder Top Arms
Is anyone able to confirm the exact lemforder part numbers for the front upper arms please?
Why?
Because if I look up the Audi part number and cross reference it, I get a different set of numbers than I do if I use the AUTODOC and ECP parts lookup against our cars.
So I’m now confused.
Why?
Re: Lemforder Top Arms
I did.
Lemforder's catalogue lists 21030 01 as a compatible part with the RS6.
But lemforders Audi x-ref part numbers for this part does not include 8E0 407 509 P
And if I then search for 8E0 407 509 P on the lemforder site, I get lemforder part number 21613 01, which does have the RS6 part number as a cross reference
Both listed as an upper front right control arm.
Any clue?
Any clue?
Just did them on mine, here are the exact ones I ordered:
https://www.auto-doc.ch/lemforder/1256603
https://www.auto-doc.ch/lemforder/1256601
https://www.auto-doc.ch/lemforder/1256599
https://www.auto-doc.ch/lemforder/1256597
So you’ve got the ones that cross reference based on part number, not their parts guide. I assume they fitted and all is good with them?
Anyway. Ordered. Same ones as you. Thank you.
Fit like a glove and visually exact match
Yeah, I always use part number x-ref, but this time came up with different numbers, which was odd. Anyway, all on order and looking forward to wrestling with the pinch bolt
In my experience the easiest way to remove the pinch bolt if stuck is:
1) Cut it as close as you can to the housing
2) Drill a hole in the center of the bolt
3) Air hammer it out with the pointy bit
Good luck
Good luck
All done with the lemforder arms as listed above. Also did the front ARB drop links at the same time - and as above, lemforder are the OEM (Audi logo is ground off). I got the drop links from ECP:
* https://www.eurocarparts.com/search/610441165
* https://www.eurocarparts.com/search/610440935
