Brexit
Astrosquirrel
Re: Brexit
Post by Astrosquirrel » Sat Nov 05, 2022 11:06 pm
Lander91 wrote:In case anyone is interested Audi Tradition is running a clearance sale.
https://shops.audi.com/assets/cms/conte ... 2280c.xlsx
Fair chunk of applicable parts for our C5s, and RHD things too e,g. some carbon interior trim etc.
Noice!
Sent from my 2107113SG using Tapatalk
steve2003rs6
Re: Brexit
Post by steve2003rs6 » Sun Nov 06, 2022 11:45 am
Astro. The pipes (flexi and solid) I got from RSCarparts are all new.
I believe they have them made to the original spec.
I believe The new oil cooler is similar and manufactured to the original spec.
Also very recently managed to obtain a used radiator.
In storage at the moment.
Cannot decide whether to keep it for future use or send it away as a pattern and get a new rad made up.
Astrosquirrel
Re: Brexit
Post by Astrosquirrel » Sun Nov 06, 2022 11:59 am
steve2003rs6 wrote:Astro. The pipes (flexi and solid) I got from RSCarparts are all new.
Hmmmmm. Wonder if it possible to fill it with coolant and store it to prevent rust...
Re: Brexit
Post by Shoppinit » Sun Nov 06, 2022 12:06 pm
It's likely be all aluminium and plastic.
steve2003rs6
Re: Brexit
Post by steve2003rs6 » Sun Nov 06, 2022 12:46 pm
Yes that was my thoughts on the rad.
But I will get it pressure tested prior to installation if I go that route.
Re: Brexit
Post by Shoppinit » Sun Nov 06, 2022 12:48 pm
Why don't you put the new rad in and send the old one for copying?
steve2003rs6
Re: Brexit
Post by steve2003rs6 » Sun Nov 06, 2022 12:54 pm
Hi Ben. The slight coolant leak I had on the bottom left hand corner has stopped quite some time ago.
Have not topped up the coolant reservoir for months.
As you suggested I intended to do exactly that.
But whilst it isn’t leaking decided to leave it for now.
And concentrate on other minor stuff
Astrosquirrel
Re: Brexit
Post by Astrosquirrel » Sun Nov 06, 2022 1:25 pm
steve2003rs6 wrote:Yes that was my thoughts on the rad.
I'll go that route too. Shop's got a point though. If just plastic and alu then no corrosion risk. Can't hurt to fill it though, right?
steve2003rs6
Re: Brexit
Post by steve2003rs6 » Sun Nov 06, 2022 2:09 pm
It’s all packed up and stored.
So won’t be filling it with water.
Ally and plastic should be ok until I need it.
Astrosquirrel
Re: Brexit
Post by Astrosquirrel » Sun Nov 06, 2022 2:24 pm
steve2003rs6 wrote:It’s all packed up and stored.
So the missus knows you're secretly building another RS6 bit by bit?Image
steve2003rs6
Re: Brexit
Post by steve2003rs6 » Sun Nov 06, 2022 2:36 pm
The missus hasn’t cottoned on yet.
But the bank manager has ?????????
Users browsing this forum: Bing [Bot], Marcin and 83 guests
