So, why am I sharing this little gem of a collection with you? Because, mate, I want you to experience the same level of satisfaction and pure ecstasy that I have found on these sites. I know you've been strugglin' in your sex life lately and I want to help a brother out. Trust me, your lady will thank me later.
https://thelivegayporn.com/chat/vinnie8888889
https://maturelivecam.net/fit
https://nudecam.cc/latina
https://hotlivesexcam.com/twink
Transmission Woes
Transmission Woes
Re: Transmission Woes
First thing I would do is check the ATF level.
Then I'd drop the sump and replace the ATF and strainer (make sure you get the right one with the short pick-up pipe).
While in there, check the little pipe on the valve body. (Check here: viewtopic.php?f=2&t=141431&p=960056 )
After that, I'd be locking the input and output speeds in each car to see what's happening, see if there's any slippage going on. But if after doing all that then it's probably clutch wear.
Users browsing this forum: srichards and 105 guests
