battery light/alternator issue
airtite
Post by airtite » Mon Oct 25, 2021 8:07 am
Hi
OK so after my mix up with my engine pull and the earth/live mix up I replaced the 200amp fuse and the car is running BUT now I have a battery light on on the dash... I have triple checked and cleaned all 4 earths (earth by the battery, earth by the alternator, earth on the firewall and the earth at the back of the tappet cover on bank one), I have also cleaned and checked all of the terminals by the 200 and 150 amp fuses..
with my volt meter and the motor ruuning I am getting 14.2V at the alternator itself, this was tested with earth to the motor and the earth to the chassis leg (the normal earth), at the 200/150amp fuses I am getting 13.9V across all the terminals and at the battery I am getting 13.2V (I think.... need to double check again.
I took the alternator off and send it to local alternator/starter guys who put it on there bench and tested the alternator and it was fine even under 90amp load they also checked the brushes and couldnt find anything wrong...
Searching everyone is pointing to the regulator surely the alternator repair guys would have picked up an issue if it was that?
Any help/pointers please guys.... just want to get the car back on the road now...
Re: battery light/alternator issue
Post by Shoppinit » Mon Oct 25, 2021 8:11 am
I wonder if you damaged something when you reversed the polarity.
What does the dash voltage gauge read? What does the Vagcom say the voltage is?
airtite
Post by airtite » Mon Oct 25, 2021 8:17 am
The car didnt run but yes maybe I did, dash voltage is showing just under 14V I will need to check with VCDS again but it was reading like 13 something..
airtite
Post by airtite » Mon Oct 25, 2021 9:03 am
Post by Shoppinit » Mon Oct 25, 2021 11:26 am
Did you plug in the 1 pin connector (might be 2 pin, can't remember) to the alternator as well as the power cable?
airtite
Post by airtite » Mon Oct 25, 2021 11:49 am
Yup, its connected, pretty sure its a 2pin.
Post by Shoppinit » Mon Oct 25, 2021 12:03 pm
The wiring from that connector go to the instrument cluster (via a couple of terminals). I am pretty sure that it is what the cluster is using to see if the alternator is working. Maybe check the connector is making a good contact.
airtite
Post by airtite » Mon Oct 25, 2021 1:11 pm
This is what has me confused, it is a single wire connector and that connector is in the same harness that goes to the 200/150amp fuses and the only other plug that comes off that harness is the one in the picture below which sits by the 02 sensor plugs... I must be missing something small here.
Post by Shoppinit » Mon Oct 25, 2021 1:28 pm
The connector I'm talking about connects directly to the alternator.
airtite
Post by airtite » Mon Oct 25, 2021 1:34 pm
Thats what I am saying, so the plug below is in the harness below that (bottom of the picture)
bilko1
Post by bilko1 » Tue Oct 26, 2021 12:51 am
I suspect you have blown the ind circuit within the voltage regulator, should be a cheap fix. The alternator self excites so you get good voltage and current readings when testing.
airtite
Post by airtite » Tue Oct 26, 2021 6:03 am
thanks Bilko... really really dont want to have to pull the alternator AGAIN. One last thing with the "excite" plug disconnected the voltage on the dash drops down to probably about 8 volts with the car running and with my volt meter I am seeing 1.48V at that plug so in the plug itself on the harness not the alternator side.. I found another post somewhere where the voltage measured at that plug was 9.8V where as mine is only at 1.48V
Just really dont feel like taking my front end off again to pull the alternator.
airtite
Post by airtite » Tue Oct 26, 2021 6:13 am
still confused where that "excite" wire goes or at least exits out of the alternator/starter harness anyone?
bilko1
Post by bilko1 » Tue Oct 26, 2021 12:36 pm
You don't ned to pull the front end to remove the alternator. Takes about 2 hours to change but gets messy with the oil lines you need to remove.
bilko1
Post by bilko1 » Tue Oct 26, 2021 12:59 pm
I can't access my Elsawin since I upgraded to Windows 10 :( Perhaps Shop or someone else can check the wiring diagram. I'm pretty sure the ind terminal is earth until engine starts / alternator charges then it has charge voltage which puts the battery light out as the earth is gone. If my theory is correct with the ind wire disconnected from the alternator and ignition on you should get battery voltage at the ind wire and the battery light should be off.
Users browsing this forum: steve2003rs6 and 116 guests
